Increase ESL perforated panels hole size...??? - Page 2 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 8th May 2012, 05:33 PM   #11
I was thinking about that last night,And I am wondering if setting the stators with the holes off center or misaligned might help that a bit?
As opposed to the holes lined up at least there would be more force on one side of the holes and the effect would be distributed evenly between the two sides.
jer
Old 8th May 2012, 09:29 PM   #12
bolserst's Avatar
It certainly seems logical that staggering the stators would smooth out drive force on the diaphragm.
Test results posted here for aligned vs staggered stators shows that you don't be lose SPL one way or the other.
So, averaging of the force over the diaphragm area with staggered stators is a logical conclusion.
Some More Questions On ELS Design
The downside of staggering of course is loss in optical transparency.
Decisions, decisions....
Old 9th May 2012, 12:50 AM   #13
AVWERK is offline AVWERK  United States
AVWERK's Avatar
Looking at the quad 57 mid/ tweeter arangement you have way less open area and both are offset significantly....go figure
David
Old 9th May 2012, 02:32 AM   #14
All good points, I must admit there is a proportional degree in the increase of the WAF (Wife Acceptance Factor) to the increase in visual and optical transparency. I must admit I too prefer that look.
....Ultimately this was the reason for the inquiry, I believed that the increase in open area would decrease the amount of metal necessary to move the diaphragm however, I am using a 6um film which likely takes 1/2 the force compared to the 12um to stretch. I would guess that it may take less energy to move, but would require greater bias power to increase sensitivity...?
Old 9th May 2012, 05:12 AM   #15
Yes,Bolserst I do remember that discussion,Only the dimensions were not included.
If memory serve me right It was determined that the hole size under a certain dimension made little difference in performance, but open area certainly does effect how it sounds.
But when the hole size increases significantly to effect performance then a second look at the theory of staggered vs Non-staggered may be in order.
Just a few thoughts.
jer
Old 9th May 2012, 03:49 PM   #16
While a more open stator looks transparent which is pleasing I believe it is the wrong way to go for performance. I would imagine that around 30% open perhaps even a little lower (27%) would be about optimum. Greater air load is what I think is needed. Best regards Moray James.
moray james
Old 10th May 2012, 12:30 AM   #17
Very interesting James, This almost seems counter intuitive as it would appear that with a reduction of air between the diaphragm and stator would decrease sound output. I am currently using 51% open area and I couldn't imagine it could sound any better by increasing or decreasing open area.
Old 10th May 2012, 07:12 AM   #18
smaller open area more load due to increased resistance. From 27 -33% open are is probably about right. Lowest open area I built was about 35%. Easy enough to test. Diaphragm to stator spacing would not change. Best regards Moray James.
moray james
Should I increase my amp size? steven2583 Subwoofers 10 24th March 2012 01:59 PM
Cutting my own perforated panels joojoo1234 Planars & Exotics 6 28th November 2011 08:34 PM
Dipole sub hole size Deodato Subwoofers 3 1st January 2011 11:02 PM
bass matrix hole size....does it matter i4gotmyid Multi-Way 1 5th October 2007 04:27 PM
PCB Hole Size ptah Parts 10 30th November 2006 02:51 AM
Copyright 1999-2017 diyAudio
