Ribbon tweeter Matching Transformer That really Works - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 5th May 2012, 08:19 PM   #1
fooeywuffle's Avatar
Default Ribbon tweeter Matching Transformer That really Works
I tried regular iron cores, and they are more than 50 percent lossy, so tried Ferrite. The size of the core is 2 3/16 inches square and no gap. It is wound based on RF tech used for transistor linear power amps, so not an easy job. For ribbon resistance of .03 ohm, which is what the ones I made are, the ratio is 17 to 1. just for 36 watts, that is 36 amps on secondary! I used 5 mil copper sheet that is wound so it is a tube when done. layer of foil, wind 16 turns of 2 ea #21, then another foil. Side ends are pinched together and soldered making it a flatened tube. 4 of these in series to complete it. The connection ends of both of the foils has a piece doubled over and soldered. This is because of the high current. I tested it for the amount of voltage it would take with little loss. For 3 Kc lowest frequency, it would take 35 volts RMS, which at 8 ohms is over 150 watts! The ribbon won't even handle that! This has almost 100 percent coupling, and very little loss.
How to make a good transformer for ribbon tweeter? pecamuzicar Planars & Exotics 189 3rd July 2015 04:38 PM
STRATHEARN ribbon matching transformers bikelectro Swap Meet 0 8th March 2010 12:09 PM
Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate lduarte1973 Multi-Way 3 16th June 2009 08:50 AM
Matching dispersion between ribbon and woofer Defo Multi-Way 8 12th June 2009 12:29 AM
Matching Ribbon ( planars ) with cone woofers?? JinMTVT Multi-Way 3 15th October 2004 09:23 PM
Copyright 1999-2017 diyAudio
