BG Neo 3 Headphone project - Page 8 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 16th July 2012, 09:56 PM   #71
Originally Posted by Remlab View Post
A bit....
Still not a great idea for a publication to get basically "the planar guy" to do the article. Doesn't pass the smell test if you catch my drift.
Just playing devils advocate, because obviously, I love his work.
Greg
Old 16th July 2012, 11:04 PM   #72
Remlab is offline Remlab  United States
Greg
I was just trying to be funny. One subjective article followed by another, less, but still subjective article. You have to admit though, that writing for a peer reviewed magazine is different than writing for your own website..
Seth
Old 17th July 2012, 12:17 AM   #73
Greg
Seth
OK, you got me...
Old 17th July 2012, 06:06 PM   #74
Cyan is offline Cyan  Italy
Thx, I will read it as soon as I have time .
Nevertheless, I have to admit that I've desperately fallen in love with TRUE ribbon tweeters , and I only have a "cheap" true ribbon tweeter (fountek neocd 3.0). I wonder how subjective I am myself, but even when I go to hi-fi shows, the speakers that impress me the most are true ribbon ones .
Edit: didn't want to read everything in the end . What I can say, is that though true ribbon tweeters are fragile, raal ribbon (in particular the OEM version) is absolutely not, but it can compete with some of the best 1'' dome from this point of view too. My fountek for instance is crossed at 3.2k with a 3d order .
Old 17th July 2012, 09:23 PM   #75
Not only are a lot of true ribbons beautiful sounding, But most are also beautiful looking. Ribbons are easily the most 'high end' looking of any driver.
Unlike a good ribbon though, a good dome can easily do 1.5khz with a 3rd order, and a Neo 3 can do it with a 4th..
Old 18th July 2012, 03:23 PM   #76
Planars do have indeed tremendous resistance and power capabilities. The raal ribbons will work up to 200mw on average (according to the white paper). The audeze lcd-2 (planar) can sustain 15w, for at least 130db sustained .
Nevertheless, the audeze lcd-2's dynamics seemed compressed, just like it is explained on the raal headphones white paper.
Old 20th August 2012, 08:00 AM   #77
Having too much bass in a planar headphone is usually an alright place to be, no? If you didn't believe in damping, couldn't you try A) Venting the pleather pads you currently have if they aren't vented already, B) Use velour pads instead, and/or C) Add reflex segments to the back magnet structures such as what's seen on the EAH-820?
Cool project, btw.
Old 20th August 2012, 08:57 AM   #78
No matter what I tried(And believe me, I tried) I couldn't get the 3khz range up to where it needed to be(Very dull sounding), in order to compensate for the HRTF. It could be that it was the PDR that was causing the problem. The regular Neo 3 just might work, but it would still be too heavy for normal headphone use..
It's not what you don't know that causes trouble. It's what you do know that just ain't so..Mark Twain
Old 20th August 2012, 09:14 AM   #79
Here is the Audeze LCD3. the bottom (gray) curve is how a good planar headphone should measure, in order to sound like the (perceived, colored)top curve. The actual measured response of the Neo 3 headphones looks more similar to the top curve. Not a good thing.
http://www.innerfidelity.com/images/...5circa2012.pdf
Old 2nd December 2012, 07:42 PM   #80
What an interesting thread!
I have a pair of Neo3 PRDW's which were at the time of reading this thread just lying around. So, I popped the back off, pressed them against my ears and was very impressed with the sound... After some playing. As it has already been pointed out, positioning matters immensely. I found if I squeezed them against my head as tightly as my ears would allow, they would produce relativity deep bass response. Beyond that, various levels of pressure/distance from my ears as well as vertical and horizontal placement would produce surprisingly different results with minimal variations. I've ordered a pair of the monoprice headphones aforementioned. I look forward to further experimenting!
Bg Neo 10 and Neo 8 InclinedPlane Planars & Exotics 251 8th October 2016 05:18 PM
BG NEO 10 pair as new inertial Swap Meet 20 31st January 2009 06:20 PM
Bg neo 10 measured inertial Multi-Way 12 7th October 2008 05:42 PM
BG neo 10 measured inertial Planars & Exotics 0 30th September 2008 09:00 AM
Jordan JX92 w/ BG NEO 3? flatwallet Full Range 9 25th July 2008 03:26 PM
Copyright 1999-2017 diyAudio
