BG Neo 3 Headphone project - Page 7 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 13th July 2012, 01:34 AM   #61
Originally Posted by Remlab View Post
True ribbons are always inherently high in THD below a certain point. It will be interesting to see how this is addressed. The expert I mentioned was critical of some ' very misconceived' points made in the white paper. This certainly does not mean that Alexander can't make a 'world killing' headphone/amp combo.. That's what makes this hobby so much fun.. Go Alexander!
ALL tweeter size drivers are inherently high in distortion below a certain point...
Don't mistake typical headphone drive levels versus loudspeaker drive levels. How do you think a typical headphone driver would measure for THD at say 90dBSPL at a foot? Not pretty at all. Let's go in reverse now and use a driver capable of being used in speaker system. It's now on virtual cruise control when used as a headphone driver. All just hypothetical of course, BUT may hold water in this case.
Greg
Old 13th July 2012, 04:35 AM   #62
Remlab is offline Remlab  United States
I'm sorry, I should have clarified what I was saying. I'm making a linear assumption. If a ribbon driver's distortion starts shooting through the roof at around 1khz at "normal" listening levels compared to other high quality designs, what is going to happen at 20 hz or even 100 hz at normal headphone listening levels? I think a ribbon driver is going to have much higher distortion at those levels and frequencies simply because of the extremely steep distortion trend they exhibit at around 1 khz at normal levels. An assumption.. And of course it could be wrong. Only time will tell..
Hey, I've got an idea, run one of your ribbons full range and play a 20 hz signal through it at headphone listening levels with your ear almost right up to it. If it sounds clean..
Old 13th July 2012, 05:17 PM   #63
default page
http://www.zaphaudio.com/nondomes/standard.html
http://www.zaphaudio.com/tweetermishmash/compare.html
I do think that "rough" conclusions can be drawn from these measurements.
Old 13th July 2012, 06:34 PM   #64
Cyan is offline Cyan  Italy
default page
Zaph|Audio
Zaph|Audio
Nothing personal, but those links are too old.
Again, as I've just said, even many people who didn't like true ribbon tweeters at first, have started to appreciate the raal oem tweeter.
It works in a "secret" way (one must sign an nda contract before buying it), that allows it to be flat in frequency response (while for instance my fountek neo cd3.0 is a little bright above 14khz), and very low distortion, even at lower frequencies. That is, it can be crossed at 1.8khz with just one capacitator .
To put it in a nutshell, the raal oem tweeter doesn't have anything to do with those links. And I hope that these headphones are strongly based on that tweeter. Again, I'm still NOT 100% sure about these headphones, at least until some measurement is published.
Old 13th July 2012, 07:01 PM   #65
This is the only data sheet I could find on that particular RAAL..
RAAL_70-10XR Ribbon Tweeter
Too bad there's no distortion plots.
It says 10xr here, but it is 20xr on the datasheet..
Old 13th July 2012, 07:10 PM   #66
Lol!! How could you find it? I was never able to find anything specific, as it is under nda. Will read it later.
Old 13th July 2012, 07:51 PM   #67
I googled "RAAL 70-20XR pdf"
Very limited data though. Oh well..
Old 16th July 2012, 01:21 AM   #68
The graph kind of looks like a dipole Neo 3, but with less extension..
http://www.stonessoundstudio.com.au/...on_tweeter.htm
http://www.audiocircle.com/gallery/a...25/Neo3pdr.gif
Why would anyone want to hide measurements if they're good? Great measurements are great for business. Am I Right? Measurements won't give away any technological secrets. So why not post them? C'mon Alexander, post the measurements..SHEESH!
Old 16th July 2012, 04:32 PM   #69
There is a great difference between true ribbon and planar (or non true ribbon). Here is it explained: Transmission Audio Inc.
Even if it's not always measurable, I believe the true ribbon to be more neutral and detailed. In addition, the true ribbon can have the resonance frequency below 20hz, and that's why it SHOULD (again we need to wait for these headphones) be better than planar headphones (like the audeze lcd-2).
Old 16th July 2012, 10:15 PM   #70
I prefer this one. A bit more objective..
Understanding Tweeter Technology - CE Pro Spotlight Article from CE Pro
Bg Neo 10 and Neo 8 InclinedPlane Planars & Exotics 251 8th October 2016 06:18 PM
BG NEO 10 pair as new inertial Swap Meet 20 31st January 2009 07:20 PM
Bg neo 10 measured inertial Multi-Way 12 7th October 2008 06:42 PM
BG neo 10 measured inertial Planars & Exotics 0 30th September 2008 10:00 AM
Jordan JX92 w/ BG NEO 3? flatwallet Full Range 9 25th July 2008 04:26 PM
Copyright 1999-2017 diyAudio
