BG Neo 3 Headphone project - Page 11 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 7th June 2013, 12:02 PM   #101
Why don't you do what I did, buy 2 cheap large headphones , strip them and build small diaphragm, and use small neos, and 2.25 mm wide aluminium foil, fix it all together total weight 405 grams. They sound wonderful. Can listen to music all day, and watch tele with them on. No problem. Everything sounds so natural it is unbelievable. Am buying more cheap headphones to convert.!!
HENRY
Old 12th June 2013, 04:05 AM   #102
James: I'm very interested in what you did there. What is the aluminum foil for exactly? Would you be able to post pictures?
Rem: I've been experimenting with cup designs-- fitting the neos to my ears at the perfect angle-- by building up this stuff I bought at my hardware store called "sponge rubber weatherstrip." I've found with this stuff, (unlike the leather pads that came with the monoprice cans) that a certain balance can be achieved between placement and band extension which makes them acceptably wearable, even bordering on comfortable, despite their weight. When using the leather pads, I would often find sharp pains on the top of my head in the exact location the headband was resting... hmm...
Edit: Sponge rubber weatherstripping is identical to what some people use to seal speakers in boxes as apposed to that grey glue stuff. I bought some from PE. From what I can tell it is 100% identical, but can be had for less at a local hardware store.
Old 12th June 2013, 08:46 AM   #103
Default pictures of my headphone rebuilds.
some pics of my headphone rebuilds using perforated sheet, foil ,mdf, and ingenuity. Great sound well worth the effort.
HENRY
Old 12th June 2013, 08:50 AM   #104
Default some more pics
Showing the evolving headphone, thro' it's various stages.
HENRY
Old 12th June 2013, 08:57 AM   #105
Default more pics
A continuation of the process of the top of my head, depending on mistakes etc.
HENRY
Old 12th June 2013, 09:02 AM   #106
Default last few pics
Have other cheap headphones on the way for more rebuilds, keep the old brain ticking over.
HENRY
Old 12th June 2013, 09:22 AM   #107
Have started on next rebuild smaller than these, so maybe too difficult to finish we shall see he said more in hope than anger.! I think I have bigger ones coming we shall see, today or tomorrow? I don't do a double diaphragm at the moment, a single one is hard enough as the ease of the layout depends on what you receive in your cheap headphone carcass! I suppose I am very lucky in the amount of time I have being retired, still one must use ones time left!!
HENRY
Old 12th June 2013, 09:23 AM   #108
I hope these pics are of use!?
HENRY
Old 12th June 2013, 11:08 AM   #109
Great pictures!
The 2.25mm aluminium foil, where did it come from?
Is is self adhesive (sticky back) ?
Is it one continuous strip even round the U-bends, if not, how do you ensure reliable conduction between multiple strips?
cheers!
Old 12th June 2013, 05:23 PM   #110
the 2.2 mm was cut by my hand, right down from 9 mm, it is self adhesive and is in one continuous piece. Not a good idea in separate strips!! To get more sensitivity I may cut the 3 mm tape in half and use that in the epsilon type layout. This increases the impedance and the sensitivity, killing 2 birds with one stone.
HENRY
Bg Neo 10 and Neo 8 InclinedPlane Planars & Exotics 251 8th October 2016 06:18 PM
BG NEO 10 pair as new inertial Swap Meet 20 31st January 2009 07:20 PM
Bg neo 10 measured inertial Multi-Way 12 7th October 2008 06:42 PM
BG neo 10 measured inertial Planars & Exotics 0 30th September 2008 10:00 AM
Jordan JX92 w/ BG NEO 3? flatwallet Full Range 9 25th July 2008 04:26 PM
Copyright 1999-2017 diyAudio
