The ultimate 2.1 system - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 25th April 2012, 12:05 AM   #1
housemd's Avatar
Default The ultimate 2.1 system
dear diyAudio fans,
I am just starting to realize a long lasted dream to build my own loudspeakers. My requirements are:
- natural life like sound at all frequencies
- dsp controlled for room adjustments
- each driver with its own amplifier
- small dimensions and living room compatible look
So my search in the internet over months led my to the following conclusion:
- 2.1 system is the only way to keep dimensions small
- while still be able to have a solid low frequency fundament
- active system with intergrated dsp is the best solution
and the following order of drivers and amplifiers:
Satellites
-Tweeter BG Neo3 PDR
-Woofer Seas W15cy001
-amplifier Hypex AS2.100D
Subwoofer
-subwoofer Seas L26Roy (2x)
-amplifier Hypex PSC2.400
The idea is to cast the satellites case in conrete while the front panel is machined in an 2 cm thick aluminium plate. The backwall will be mainly the panel of the hypex plate amplifier.
The subwoofers material and look is not yet decided, but according to other forum i would like to try a so called Ripol configuration in order to keep the dimensions as small as possible. This kind of subwoofer will also allow to go very deep in base but with bad efficiency. That is also the reason for the strong amplifier.
I will upload some designs/drawings tomorrow and hope for some feedback if i am going into a wrong direction. (speakers and amplifiers already arrived.. So there is no big change affordable).
Satellite design: Click the image to open in full size.
Subwoofer design:
Have a nice day,
Old 25th April 2012, 12:34 AM   #2
diyAudio Member RIP
A ripole doesn't just have bad efficiency, it has very bad max SPL compared
to a sealed or vented box. You can make small twin sealed sealed sub boxes
and LT them to any desired response. Understand that bipole "baffle loss"
is not just a response roll-off like from a box, it chucks away excursion.
rgds, sreten.
Old 25th April 2012, 04:49 PM   #3
housemd's Avatar
Thanks Sreten,
I will reconsider the subwoofer idea and hope with closed box theres is not too much base in the house. There was written that Ripol system would not produce any standing waves in the room since they are eliminated by the phase shifted signal on the other side of the box.
For a closed system calculations showed me for L26Roy something between 27-40 liter should be fine.
Old 25th April 2012, 06:18 PM   #4
That sounds like your typical multi-way.
If you want natural sounding you should consisder an ESL or a dipole type system or even DIY ribbons.
You can do those type's of systems sometimes very cheaply and on a budget and get much more sound quality than you would with the typical multi-way setup.
It is just a thought being that this is the Planar and Exotic forum.
jer
Old 25th April 2012, 09:00 PM   #5
CharlieM's Avatar
jer
I agree... the sound from a line source ESL is downright spooky.
Old 26th April 2012, 05:42 PM   #6
housemd's Avatar
Your DIY ESLīs look amazing, unfortunately i donīt have enough space available.
Old 26th April 2012, 05:45 PM   #7
housemd's Avatar
Thanks for the hint that one can produce ESL DIY. You might be right but i have limited time available and have to reduce DIY work accordingly.
BTW I would like to use the ribbon as tweeter and first thought to use a dipole as subwoofer... thought it would be exotic enough :-)
quest for ultimate portable all weather sound system tedlevit Introductions 2 10th February 2008 06:46 AM
Whats your ultimate DIY system? fatmarley Everything Else 0 7th December 2007 10:19 AM
ultimate low cost FR system regal Full Range 35 19th August 2005 04:51 AM
Priniciples in building the ultimate electrodynamic speaker system conscious Multi-Way 55 29th March 2005 09:08 AM
search for ultimate system mvagusta Multi-Way 25 10th September 2004 06:04 AM
Copyright Đ1999-2017 diyAudio
