Acoustat Model 3 Questions - Page 4 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 21st July 2012, 03:13 PM   #31
tyu is offline tyu  United States
Just setup stock with 5 diodes....an sale them....or cook ever amp you got...an not sound good ...right...if the bias is down the amps sees like a Dead short..Not good for the tranfourmers..
I think that even if there is 5k in the box... it so close to the Mixer setup it get pulled down....what 5k.. it one inch away from the hi-low tranfourmers......Jim would have done this diff but for cost..
I fine it funny that know talks about this...it only the bigest prom with any ESL..if you got a good panel...get the bias right you got the best sound ever....but if the bais is off...low SPL..need a BIG amp...an it still not right the sound is rolled off..base blures...thay just dont sound right...people sale them an that ok more for me...
My Acoustas sounds better than ever...With a good bias....Moray has done this diode mod...Search....goodluck
Old 21st July 2012, 04:11 PM   #32
john65b is offline john65b  United States
john65b's Avatar
So, output of the 5x multiplier(assuming no losses) is 1060 x 5 = 5300VDC.
Bolserst,
This is what I always understood...doesn't make it right, but it does jibe with all that have actually tested the output voltage (around 3750v)...doesn't this make sense?
5 x 750VAC = 3750VDC?
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V
Old 21st July 2012, 04:32 PM   #33
Originally Posted by bolserst View Post
The sections of the voltage multiplier are charged up to the peak of the AC waveform like any other rectified power supply with filter capacitors. The peak of the 750VAC waveform is 750 x sqrt(2) = 750 x 1.414 = 1060Vp.
On paper hes right...I think....?
But i am assuming theres losses...goodluck
Old 21st July 2012, 04:37 PM   #34
bolserst's Avatar
Hello john65b,
I think you grabbed your image from wiki page here:
Voltage multiplier - Wikipedia, the free encyclopedia
Note that in the first sentence of the operation section it defines "Us" as the peak voltage of the AC source, not the RMS value. For the Acoustat supply RMS = 750, Peak = 1060.
I have measured many properly working Acoustat HV supplies with Fluke HV probe and the output voltage is as described. If the output measured with a HV probe is much lower than 5kV the answer isn't to add more sections, but to track down the problem which is usually leaky/faulty diodes or capacitors.
As Tyu mentioned, even though Acoustat designed the supply to output 5kV, there can be sound quality advantages to increasing it a bit if your particular panel can handle it without ticking/crackling noises or the diaphragm collapsing to one of the stators. Acoustat used a more conservative HV level that would work for all panels coming out of a production situation.
Old 21st July 2012, 05:02 PM   #35
Yes Yes....i say it lest one can do with A 30year 5k bias... is spend $50 an re-work ea. bais board...these panels are worth it....but most just say these things are hard to drive...the top-end sucks so ...next.. . An as for how Much bias a Acoustat needs there just like the Soundlabs youll hear a buzz when you gone to far...then back of a litte Sweet sound....Long live Acoustats
Thanks for the info bolserst....goodluck
Old 21st July 2012, 05:58 PM   #36
john65b's Avatar
I stand corrected... Peak, not RMS...Thanks Bolserst
I wish had a HV probe to test the actual voltage. I have a cheap Craftman Voltmeter that reads up to 1kv, and I have a Varaic, so I set the Variac at 25VAC out to the interface to see if I would get 1/5th the 5kv, but got goofy voltages, once again I forgot my multimeter loading would affect the voltage readings...any other quick way to find a bad cap/diode without actually removing it?
Can I use my cheap Craftman voltmeter across each diode and look for 1050v, or does the probes/meter have to be rated for HV?
Old 21st July 2012, 09:41 PM   #37
bolserst's Avatar
What is the model number of your voltmeter? Does the instruction manual state what the input impedance is?
If you only have this meter, I would recommend setting the Variac so that the output of the HV transformer measures 100VAC.
Then, switch to DC mode on your voltmeter and:
1) measure the voltage between ground and the output of the ladder network (before the large 500Mohm resistor)
If we know the input impedance of your mulitmeter, we can run spice simulation to determine if your reading indicates trouble in the multiplier.
2) Be sure to perform measurement 1) first so as ensure all capacitors have been discharged thru current draw to a level indicative of the 100VAC input.
Then, measured the DC voltage across each of the capacitors.
Ideally, with no losses and 100VAC input:
C8 = 140 VDC
C6, C7, C9, C10 = 280 VDC (as you work down the chain, these will measure progressively lower due to your meters input imedance)
Let me know what the results are, and I can try and help you decide if there is something wrong with your supply.
Old 22nd July 2012, 04:15 AM   #38
john65b's Avatar
Yes, I will try tomorrow.
It is a craftsman 82345, and only goes to 600VDC and 600VAC, not 1kv.
It has an VDC impedance of 10M Ohms, and VAC Impedance of 4.5M Ohms.
Old 22nd July 2012, 02:50 PM   #39
john65b's Avatar
OK, I removed the additional diode/cap, so we are back to stock.With 100VAC from bias transformer...
The entire ladder - 109VDC with my 10M Ohm multimeter
Across C8 - 105VDC
Across C6 - 153VDC
Across C9 - 121VDC
Across C7 - 94.3VDC
Across C10 - 81.2VDC
All measurements with Speakers (all three) connected to interface. With C8 only at 100VDC, is D1 dead?
Old 22nd July 2012, 05:23 PM   #40
Thanks agine for this info bolserst....most would never think of this...
Acoustat Model 2MH modding hatrack71 Planars & Exotics 1 23rd December 2011 10:41 PM
Need help with Acoustat Model 4 speakers skykomish Planars & Exotics 13 3rd January 2011 10:15 PM
Acoustat model 141-C speakers available timbuckstwo Swap Meet 0 17th April 2006 09:10 PM
Acoustat model 141-C speakers available timbuckstwo Swap Meet 0 11th March 2006 09:45 PM
Acoustat model 141-C speakers available timbuckstwo Swap Meet 1 5th December 2005 07:31 AM
Copyright 1999-2017 diyAudio
