Bg Neo 10 and Neo 8 - Page 25 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 5th July 2012, 11:01 AM   #241
Remlab is offline Remlab  United States
Originally Posted by StigErik View Post
A speaker that measures flat in-room will sound somewhat thin or bright. A curve that slopes down about 10 dB from 20 Hz sound more natural.... so the Jamo is still missing almost 10 dB @ 25 Hz. Toole (at Harman) did some listening tests about this, I shall try to find it.
That hypothesis can be tested here. Kind of. Equal loudness contour charts actually do substantiate your claim.
Equal loudness contours and audiometry - Test your own hearing
Equal loudness contour chart..
http://en.wikipedia.org/wiki/Equal-loudness_contour
But I have to add, my sealed system is flat to 20hz and that that 20hz sounds perfect relative to the rest of the spectrum. So I would have to say that dipole bass is so different "in room", that it needs to be lifted substantially to sound as "loud" as a sealed system at 20 hz..
Old 5th July 2012, 11:07 AM   #242
StigErik's Avatar
Found what I was looking for:
https://docs.google.com/file/d/0B97z...GQ4/edit?pli=1
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 5th July 2012, 11:20 PM   #243
Very interesting "Post" Floyd Toole (retired) work done by Sean Olive. My take on this is that when using High dispersion loudspeakers (The kind that Floyd and Sean prefer)as opposed to the more controlled dispersion types, the room will will have a lot more high frequency energy bouncing around in it (relatively speaking). This will, I think, be perceived in "normal" rooms as "treble heavy" by the listener and would need compensation in the bass to be perceived as "normal". I do think the best way to Know for sure is to listen only to excellent "purist" recordings of acoustic music containing acoustic bass while judging your system because acoustic bass can sound only one way as opposed to electric bass which can sound pretty much any way you want it to. If acoustic bass sounds thin in the lowest registers relative to its highest registers while your system measures flat (At the listening position), it would need bass compensation..
Old 6th July 2012, 08:52 AM   #244
StigErik's Avatar
Well, in normal situations reflected energy will totally dominate what we hear and what we measure at the listening position. If it measures flat, the total energy is flat, regardless of if its reflected or not. My experience is that a flat measured response sounds too thin in every case, regardless of speaker type and the amount of room reflection.
Old 6th July 2012, 08:24 PM   #245
Linkwitz also believes that a downward trend sounds more natural, but only for pure dipoles, and at 2 db per decade slope.
Old 7th July 2012, 04:40 PM   #246
jeno is offline jeno  Norway
Originally Posted by Remlab View Post
Wow! Those are cool in a kind of disturbing way... They make a lot of sense though, except the forward tilting.
Old 7th July 2012, 07:22 PM   #247
Obviously the tilt is for for aiming the high frequency units at the seated listening position. There would be pretty much only one ideal distance you could sit. Like with the larger wilson designs, but worse. At least the larger Focals have very effective multi-driver tilting mechanisms for aiming the drivers to any distance you want.
Old 31st July 2012, 11:16 PM   #248
Speaking of tilt..
http://s1252.photobucket.com/albums/hh571/remlab/
I love the Neo 10 as a mid tweet, but it does sound rather closed in off axis, so I'm going to do some experimenting with this configuration above 9khz.
Old 2nd October 2016, 02:13 AM   #249
Bill poster's Avatar
Bumping this excellent thread.
Now that PE have resumed selling the neo 10/8/3 I'd like to ask a question about the 10's- is there a way to treat or minimise the 6khz cavity resonance?
Old 8th October 2016, 02:59 PM   #250
I think you can use a correction network similar to what is adviced for the Neo 8. According to some reviews of the Neo 10, there is a rising distorsion above 2.5-3 kHz and it is also where it starts beaming. There is another way for reducing the high frequency peak of the Neo drivers. If you remove the plate (with magnets) in front of the diaphragm, the cause for the resonance is ore or less removed - the trapped air between the front and rear plates. Of course this changes the sensitivity of the driver.
F/S (3) BG NEO:10 Planar Magnetic Panels rubicon Vendor's Bazaar 1 31st December 2011 05:39 PM
BG Neo 10 (Neo10) vs. Alcons RB401, SA8535, ESS AMT, or Beyma's TPL-150 tiefbassuebertr Multi-Way 1 6th December 2011 12:54 AM
BG NEO 10 pair as new inertial Swap Meet 20 31st January 2009 06:20 PM
Bg neo 10 measured inertial Multi-Way 12 7th October 2008 05:42 PM
BG neo 10 measured inertial Planars & Exotics 0 30th September 2008 09:00 AM
Copyright 1999-2017 diyAudio
