Mini planar magnetic using neos - Page 9 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 2nd April 2012, 06:44 PM   #81
Originally Posted by Baldin View Post
Looks super cool.
A questions (which you might already have answered):
How did you cut the alu ... one long flatwire, which was afterwards attached/glued ... and if so how did you cut it up ..
Best regards Baldin
yes, there is a brief explanation at #34 Mini planar magnetic using neos
should you need furter explanations, just ask
A cold amp is a sad amp... I like them warm at least
Old 2nd April 2012, 06:53 PM   #82
Default more pics
more pics that refused to upload before:
close-up's of the babies.
the yellow stuff behind the metal sheet is a cloth to damp the membrane movement. A kind of Spontex borrowed from the kitchen
Old 2nd April 2012, 07:00 PM   #83
Baldin is offline Baldin  Denmark
Baldin's Avatar
Send a message via MSN to Baldin
If post #67 is a good infication of the freq response (the left one), then your high mids are 10 -15 db higher than low and high end ...
This will indeed sound clear and tiring ...
1. make a new freq measurement again. One where the speaker is mounted on top of your Tannoy, mic 1 meter from and at same height.
2. Make same measurement with the speaker on the desk top.
(post here)
If the high mids are still very high, you have to correct with a filter, or use a graphic eq e.g. when playing via MediaPlayer ...
Visit www.sensibleaudio.dk or read latest news on Baldin's Blog
Old 3rd April 2012, 02:02 AM   #84
gootee is offline gootee  United States
I wouldn't jump to any conclusions about the need for filtering or equalization until a redeisgn is considered, or at least until the data is corrected for the source, amp, and mic.
Very high membrane tension was mentioned. Something about overheating versus frequency was mentioned. There was confusion about what the driving power was, versus frequency. That all needs to be sorted out, first. Perhaps the actual power being converted to sound is too low (at some frequencies, at least) and the membrane tension was raised to some ridiculously-high level to try to get enough SPL, and maybe that created some exaggeration of the mechanical resonances.
Secondly, did you compare the frequency response to that of the amp alone (using an equivalent resistive load)? The mic and amp without the speaker? If not, we have nothing to base any decisions on.
You need to test with a different power amplifier, at the least, which should be one that can routinely drive 1 or 2 Ohm speakers, at every frequency, at high power levels, without any problems.
But I would take another look at the conductors on the membrane. Is the total resistance too low for your amp? The foil could be made much narrower, to raise the resistance in proportion to the width reduction. Do you know how the temperature of the foil will vary with current, for different foil widths? I would find out. Perhaps with a proper total resistance, your amplifier could produce lower frequencies with much more SPL, even with a much lower membrane tension. Perhaps with a lower membrane tension the response might flatten out.
Or perhaps you should make the frame slightly non-rectangular (one long side longer than the other, for example), so that the resonances won't all be in one or two narrow frequency bands. Otherwise, you could try clamping the membrane at one or two points, to see if it flattens the response (like Magnepan's "tuning dots").
But even if you can bring down the main peak (even assuming it's not an artifact of your amplifier), you would still then need more total SPL. So you could consider making sure that the total resistance is at least 4 Ohms. Before that, just to check if that could be the problem, you could try testing it with an amp that can drive 1 or 2 Ohms at high power without any problem.
Planar magnetic with central tweeter? Few Planars & Exotics 103 22nd March 2016 01:17 PM
help designing a magnetic planar woofer baffleman Planars & Exotics 14 18th April 2014 04:01 PM
DIY Planar magnetic Hybride WrineX Planars & Exotics 71 9th August 2012 01:48 PM
Planar Magnetic Drivers - 8" rubicon Swap Meet 8 1st December 2010 07:22 PM
ESL vs Planar Magnetic Borat Planars & Exotics 40 8th September 2009 02:47 PM
Copyright 1999-2017 diyAudio
