Mini planar magnetic using neos - Page 2 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 13th January 2012, 01:55 PM   #11
Default New membrane
Reducing the width of the aluminium strip from 5 mm to 3 mm has rised the resistance to 1.2 Ohm
Doubling the pattern on the other side of the membrane will put the resistance on 2.5 Ohm with a minimal amount of weight.
Maybe with a resistance of 2 Ohms in series this will make interesting sounds without burning any amp...
I will try to post some pics later
A cold amp is a sad amp... I like them warm at least
Old 14th January 2012, 10:13 AM   #12
Default the pics
Old 14th January 2012, 10:21 AM   #13
Default The epsilon affair
Originally Posted by JAMESBOS View Post
using this layout you won't get much sound.THE EPSILON LAYOUT IS A MUST.
I've made some calculations and the Epsilon layout is possible with the magnets availables.
also, the resistance is expected to be in the 2 Ohms region, so a doble layer will put it in a tolerable region for the amplifiers.
I expect the magnets to arrive monday or tuesday.
by that time I will try to make an epsilon membrane.
Thanks for the advise
Old 14th January 2012, 01:46 PM   #14
I did build a A4 sized planar but it wasn't very sensitive. Then I decided to try the epsilon layout, and rebuild some of my normal designs, best thing I ever did! I did build one double layout with gaps between magnets. A 4'x 2' size using 50 x 25 x 10 ferrites. Gluing the ferrites was a bind when I moved it 25 of them came undone, not worth the effort and would be nigh impossible using neos. So I built a 60 x 40 cm one using ferrites with no gaps and it was as loud as the big one with gaps!! Then I decided to use some 50 x 12.7 x 6 mm neos which I had used for another design which wasn't very successful.I have finished the pair and they are about 5db louder than my other designs.It weighs 16lbs and is 60 x 40 cms. I will build the other one to my 4' x 2' using ferrites with the epsilon layout. You get better bass with the bigger one. The impedance of the big one is 9.6 ohms and the 60 x 40 cm one is 6.3 ohms. Use a decorating roller to run over your tape, it flattens all the bubbles etc.
HENRY
Old 14th January 2012, 02:53 PM   #15
a.wayne is offline a.wayne  United States
Sin Bin
What is this epsilon layout ? do you guys have an link ?
Old 14th January 2012, 03:58 PM   #16
Take your pick these are all based on the epsilon layout.Some have been changed to go with different magnet layouts and different sizes.All the best.
HENRY
Old 14th January 2012, 04:02 PM   #17
My Apogee's use them same Voice Coil pattern.
Just to set the record straight.
And I thought the main Idea on the Epsilon panels was that a Rubber surround is used to support the diagphram rather than mounting it directly to the frame,
analysis epsilon
Keep up the great work guys !!
jer
Old 14th January 2012, 04:19 PM   #18
analysis epsilon
jer
I've never seen an Apogee up close to work out layout, the point of the epsilon layout was increased sensitivity by using all the magnet area. Not just the rubber surround. The big increase in sensitivity has nothing to do with the rubber surround.I suppose I could call it the epsilon apogee layout.
HENRY
Old 14th January 2012, 04:34 PM   #19
Here are some closeup pictures of the Apogees and it is a little hard to tell as the end of the loops are hidden by the frame,
Apogee Speakers Construction
But, you are on the right track and the more loops that you can get in there the more efficiency you will get.
The thing that the Apogees suffer from ( besides from not using NEO's) is that there is only one loop per row of Magnets.
jer
Old 15th January 2012, 10:45 AM   #20
Which depends on the width of your magnets or my prowess with a pair of scissors!! I myself have used 25, 19 and 12.7 mm wide magnets all can be used with the epsilon type layout. It is just a matter of working it out. Which was surprisingly easy, even for an old codger!!
HENRY
Planar magnetic with central tweeter? Few Planars & Exotics 103 22nd March 2016 02:17 PM
help designing a magnetic planar woofer baffleman Planars & Exotics 14 18th April 2014 05:01 PM
DIY Planar magnetic Hybride WrineX Planars & Exotics 71 9th August 2012 02:48 PM
Planar Magnetic Drivers - 8" rubicon Swap Meet 8 1st December 2010 08:22 PM
ESL vs Planar Magnetic Borat Planars & Exotics 40 8th September 2009 03:47 PM
Copyright 1999-2017 diyAudio
