Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 2nd January 2012, 03:25 PM   #1
Default Final Electrostatic Faults, repair tips needed.
Hi, I have a couple of faulty Final 0.5 panels, one has just begun to spark near the botton corner along the long edge, the other has a "blown" energiser, this appears to be an overheated component within the resin potted unit. The 2 units are from different pairs, the pair with the spark fault have 12v wallwarts and the blown energiser has a 240v mains supply. How can I repair/replace the panel/energiser. Thanks.
Old 2nd January 2012, 07:25 PM   #2
hi, i have recently repaired these had to fit new mylar film ,mine have the wall type psu cant help you with that but the noise you are hearing is probably arcing between the stator panels if there is a slight gap anywhere you will hear this sound remove panel from frame work and apply some good tape around the frame work hold the two frames together tight as you apply the tape to close the gap and that should be ok,if they have not been repaired before then the two panels will be glued together so you wont be able to take them apart without fitting new film.
Help needed, Rebuild/repair of Final 0.3 hybrid electrostatics neddy999 Planars & Exotics 7 12th July 2010 09:58 AM
marshall valvestate 8080 repair tips needed skid Instruments and Amps 4 25th April 2006 01:01 PM
amp been in for repair, not fixed need advice to trace faults mrlennon Solid State 254 31st December 2005 01:51 PM
Final 0.4 hybrid ESL electrostatic speakers affordablehifi Planars & Exotics 3 24th March 2005 09:20 PM
Page generated in 0.08123 seconds (67.52% PHP - 32.48% MySQL) with 10 queries
