Amp to Power my ElectroStat hybrids - Page 2 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 15th September 2003, 12:13 AM   #11
SY's Avatar
Coincidently, I've been using a 2B today to drive the ESL panels for watching football. The 'Niners lost, but it sounded just fine.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 15th September 2003, 12:21 AM   #12
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
SY,
I'm waiting for you to show us details of your direct-drive ESL amp design. If I remember right you theatened us with it in the tubes forum at the beginning of the year.
Class AB or not, it must be worth a view!
Old 15th September 2003, 12:55 AM   #13
SY's Avatar
I've got a low power version (900 volt) of it prototyped and working- not much SPL, but it demonstrated the concept. I'm trying to gather fundage for the Real Deal. High voltage tubes and caps are expensive, drat it, but if I can pull it together, I think it will be awesome.
In outline, what I've got going is a pair of 6LF6s (I'll need something bigger for the 5kV version, a HV zero-bias triode is the goal) running screen drive near class B. The plates are loaded by a CT choke with the B+ fed to the center tap. The stators are connected directly to the tube plates. In my proof-of-concept, I used one of the Acoustat transformers (a treble one) as the choke, connecting to the secondary and letting the primary float. I'm sure there's a commercial choke that would work better, but this is something I had laying around.
The drive is a tube-FET hybrid cross-coupled circuit I've been using for at least 20 years, using a 5691 and a pair of 2N5462s; this couples to a 5692 diff amp to get enough juice to run the output tube screens, though a nice step-up transformer would be even better (though costly). Screen drive gives you great linearity at low currents, but the effective mu is 5 or so, so you need a lot of gain and a lot of swing from the driver. The output screens are driven by a pair of high voltage Hexfets configured as source followers.
The trick to making this work is to connect the diaphragm bias supply "backwards."
And, as usual, I'm two months behind schedule
vintage no name (janzen) electrostat/ ar-2 HYBRID help!!! pictures! tyler477 Parts 4 26th February 2013 06:01 PM
Hybrids bigpanda Solid State 105 24th November 2009 09:47 PM
Room size and ES hybrids? Alabama978 Planars & Exotics 1 2nd September 2008 09:45 PM
Equilising DIY Electrostat's ak_47_boy Planars & Exotics 10 2nd November 2006 03:05 PM
Help with DIY electrostat's ak_47_boy Planars & Exotics 18 25th October 2006 10:35 PM
Copyright 1999-2017 diyAudio
