Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 6th January 2012, 11:49 AM   #21
tyu is offline tyu  United States
One thing to keep in mind....all the res. put in the bias have there own sound....
so if the res...hot on the top...get a diff res....ML uses an thay sound good carbons4 1/4watt 15m ohm.5..10m ohm....some like Acoustat use1 50mohm 20watt....thay all sound diff..
SoundLab used The rat-shk...whit sand 50w...sound bad to me...but we Diy,ers need to pay a lot more time on the Bias...this is where all good sound starts an ends
Thanks for all an any info..
Old 7th January 2012, 03:40 AM   #22
Default Measurements and other tips
Olaf-- Thanks for sharing those measurements of the Sequel without resistors. Your measurements without resistors certainly conforms to what I am hearing.
Luckily I am using a computer based system and a Tact preamp/processor, so I can adjust for the frequency response problems. After hearing the cleanliness of the sound without the resistors, I prefer to do this and not have to put the resistors back in circuit.
I read your post that you pointed me to, where you were proposing a fix for flattening the impedance and response curve of the Sequel. I will keep that in mind. I am thinking, though that I shouldn't have a problem with low impedance affecting the response given I am using the Tact fully digital amp. If I remember right it is supposed to be stable into super low impedances. I will check the impedance of the amp, though, just to be sure.
Power Mac G5 running 10.5.8 > Musical Fidelity V-Link > Tact Mini 2.2 > Tact S2150 > Modified Martin Logan Sequel IIs
Old 7th January 2012, 04:02 AM   #23
Rob in Montana
the original 10 to 15 meg power supply output resistors were carbon film becase they handle surge and voltage breakdown better than metal films used in that circuit position - the long term reliability of your metal film resistors when used as output resistors for HV power supplies usually isn't good. Usually wire round, rated carbon films, or special high voltage power film are used.
Old 8th January 2012, 03:12 AM   #24
Ticknpop--Thanks for the tip.
Dynamic Bias - Active Bias - Automatic/Self biased - Overview wanted tiefbassuebertr Pass Labs 11 5th May 2011 08:42 PM
MartinLogan Ascent i xo upgrade Pesonen Planars & Exotics 1 12th May 2005 07:57 PM
MartinLogan Speakers EchoWars Planars & Exotics 6 26th April 2005 09:36 PM
Peavey Classic 60/60 bias mod advice RIC Tubes / Valves 5 23rd March 2005 06:16 AM
MartinLogan Descent Clone: What subs? Rarkov Multi-Way 4 25th October 2002 08:16 PM
Page generated in 0.08469 seconds (73.57% PHP - 26.43% MySQL) with 11 queries
