analysis epsilon - Page 7 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 21st November 2011, 06:18 PM   #61
Thank you Brian t, much appreciated, will have a look for the magnets.
HENRY
Old 22nd November 2011, 06:38 AM   #62
brian t is offline brian t  United Kingdom
brian t's Avatar
hi, can anyone recommend a glue for sticking mylar to rubber.cheers
Old 22nd November 2011, 08:17 AM   #63
Epoxy is a sure fire glue although it can be quite messy.
Second one that work as well is super glue.
I haven't tried to use it to glue the mylar yet but I did use it to build the frames for the diagphrams for my ESL's.
jer
Old 22nd November 2011, 10:25 AM   #64
brian t's Avatar
thanks for info have tried super glue very inconsistent with mylar and is only reliable if a primer is applied first ,trouble with epoxy as you say its so messy to use what about 3m super 77 spray?
Old 22nd November 2011, 10:31 AM   #65
brian t's Avatar
what about rhino glue?
Old 22nd November 2011, 11:56 AM   #66
chinsettawong's Avatar
Rubber glue or the yellow contact cement is what I have found to be the best glue for gluing Mylar.
Wachara C.
Old 22nd November 2011, 12:14 PM   #67
tyu is offline tyu  United States
Forget the 3m,77......DAP Weldwood contact cement....It a rubbery type.....clen good with assatone.....put this on both side let dry for 15-20 min....put the two togather...
ps It wont come apart......here at WM $7US more than a nuf for 50 speakers...
i have used to hold wire to the mylar on Magnepans....work best !.
an the price is right.
Old 22nd November 2011, 12:18 PM   #68
The 3m spray doesn't hold tension very well and is more messier than epoxy.
It is very hard to get a consistent thickness when spraying out of the can and it gets all over everything.
Polyurethane glues foam up as it is curing also they don't seem to bond well with some plastics although I have never tried it on mylar yet.
I have read good results from others with a brush on contact cement as well and I may try it sometime but right now I generally use epoxy.
jer
Old 22nd November 2011, 04:49 PM   #69
brian t's Avatar
Ok cheers guys, have checked and as usual all the best glues only seem to be available in the states cant get dap weldwood here .
Old 22nd November 2011, 05:45 PM   #70
Yes you can.....It used for wood lamanet type work...i no you can get small botles with a brus in then...shool....wood work shop....it contack glue..you do one side..an then the other ... then let dry to the tuch....but thin when you put the two togather...that that..the ..Exopy get hard...this is rubbyre...work great...
epsilon lavardin amp help zerohead_ak47 Solid State 7 29th December 2008 05:02 PM
Midrange Analysis mbutzkies Multi-Way 4 25th May 2005 01:51 PM
noise analysis tenderland Tubes / Valves 5 29th March 2005 11:22 PM
cap analysis yldouright Parts 3 7th January 2005 01:45 AM
Need help in circuit analysis Fossil Tubes / Valves 6 23rd November 2004 07:13 AM
Copyright 1999-2017 diyAudio
