analysis epsilon - Page 19 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 30th March 2012, 11:51 AM   #181
DAMIC is offline DAMIC  Seychelles
Originally Posted by von.ah View Post
I'm a total noob in planar theory. What's the rationale for non-parallel long sides (highlighted in the attachment) on your larger designs? This seems to be prevalent in a lot of planar speakers.
The shape with non-parallel longer sides simply gives the best frequency response on dipole speakers. Yu can check or simulate with Edge program :
Home of the Edge
regards,
Old 30th March 2012, 08:41 PM   #182
Exclamation trapezoidal design
Home of the Edge
regards,
If that was the case, the bass panel could be rectangular like the tweeter...
But it's not is it !
Old 31st March 2012, 02:10 AM   #183
Few is offline Few  United States
My understanding is that Apogee used the non-rectangular diaphragm shape, along with tension that was set differently at the top and bottom of the diaphragm, to tune the diaphragm to different resonance frequencies at different heights above the floor. The point was to avoid one dominant and audibly intrusive resonance.
It is often suggested that using non-parallel diaphragm edges prevents standing waves but the notion that rectangles support drumhead resonances while other shapes don't isn't correct. The spectrum of the resonances depends on the shape but the resonances are there whether the edges are parallel or not.
Few
Old 31st March 2012, 06:23 PM   #184
YohY is offline YohY  United Kingdom
Originally Posted by Few View Post
....but the resonances are there whether the edges are parallel or not.
Few
I'd agree that the resonances are not totally eradicated, but are suppressed to a large extent..
Old 1st April 2012, 01:57 AM   #185
I don't agree that they're suppressed to a large extent but since I don't have data handy that I can present to back up my position I'll leave it at that. If someone has information that clarifies the situation I stand ready to admit I'm wrong.
Few
Old 22nd September 2012, 02:16 PM   #186
brian t is offline brian t  United Kingdom
brian t's Avatar
Been a while since i repaired these but wanted to see over a few months how they would perform and am happy to say its been fine so if anyone else has the same problems its nice to know these can be repaired in the field although its taken me nearly a year to source all the suitable parts and fix .
Old 22nd September 2012, 02:17 PM   #187
brian t's Avatar
Old 22nd September 2012, 02:19 PM   #188
brian t's Avatar
Old 22nd September 2012, 02:27 PM   #189
I don't know if it is a visual illusion but it seems like You have no lateral tension over the membrane as the side rubber seems to be slacking. True?
I see that You left the upper and the lower suspension out!
The one who succeeded was the one who didn't know it was impossible.
Old 22nd September 2012, 02:28 PM   #190
brian t's Avatar
As you can see i have replaced the factory bass diaphram frame with one of aliminium but this did make it a lot harder job so i would not automaticaly recommend this mod as the factory mdf /ali strip is much easier to work with.
epsilon lavardin amp help zerohead_ak47 Solid State 7 29th December 2008 06:02 PM
Midrange Analysis mbutzkies Multi-Way 4 25th May 2005 02:51 PM
noise analysis tenderland Tubes / Valves 5 30th March 2005 12:22 AM
cap analysis yldouright Parts 3 7th January 2005 02:45 AM
Need help in circuit analysis Fossil Tubes / Valves 6 23rd November 2004 08:13 AM
Copyright 1999-2017 diyAudio
