| Planars & Exotics ESL's, planars, and alternative technologies |
#161 |
Hi Brian
Made a frame of wood and drilled holes through the sides and put long screw's in. Then I glue the frame to mylar. I put a aluminum profile over the screw's and mount springs. Attach the profile to the speaker mdf and now I can adjust the tension of the mylar. Then I use aluminum tape 9mm wide from farnell for the conductors. Rob |
#162 | |
HENRY |
#163 |
Some more photos of my latest rebuild. The last but one is the old diaphragm, and the last photo is the new tape 2.25 mm wide to fit magnets on the rebuilt diaphragm using epsilon layout.
I think it's called being obsessive.!! After this it's my planar headphones, to be finished. Then it's back to the rebuilds, all that tape cutting, about 300 meters.
HENRY Last edited by JAMESBOS; 2nd February 2012 at 06:49 PM. |
#164 |
Disaster, ruined the diaphragm got to do it again! So I am rebuilding another one instead 24 x 30 inches using 50 x 18 x 10 mm ferrites. Easier to build the diaphragm not so fiddly.Although I've got to cut another 45 meters in half again.
HENRY |
#165 |
I'm a total noob in planar theory. What's the rationale for non-parallel long sides (highlighted in the attachment) on your larger designs? This seems to be prevalent in a lot of planar speakers.
#166 |
As FAR AS i KNOW IT'S TO DO WITH STANDING WAVES . i read in the first article and design over twenty years ago, so can't be of any more assistance on the matter, you will probably get better imfo from the experts!
HENRY |
#167 | |
nice work! What's the resistance of the small planars? and, how does they sound? mine are a bit weak on bass... (size matters) Regards Pedro
A cold amp is a sad amp... I like them warm at least |
#168 |
I have stopped work on these at the moment as I ruined the diaphragm fitting it to the surround, and I have not heard it at this time. The resistance of the old diaphragm was 1.4 ohms, the new one is 4.4 ohms.
HENRY |
#169 |
Does anyone know what technique Analysis uses to solder to their aluminum conductors? In some thread I haven't yet found again there was a discussion of techniques for breaking through the aluminum oxide layer while soldering but that approach doesn't seem applicable to very thin (5.5 micron) aluminum foil.
Few |
#170 |
| epsilon lavardin amp help | zerohead_ak47 | Solid State | 7 | 29th December 2008 05:02 PM |
| Midrange Analysis | mbutzkies | Multi-Way | 4 | 25th May 2005 01:51 PM |
| noise analysis | tenderland | Tubes / Valves | 5 | 29th March 2005 11:22 PM |
| cap analysis | yldouright | Parts | 3 | 7th January 2005 01:45 AM |
| Need help in circuit analysis | Fossil | Tubes / Valves | 6 | 23rd November 2004 07:13 AM |
| Page generated in 0.10722 seconds (87.19% PHP - 12.81% MySQL) with 11 queries |
