analysis epsilon - Page 16 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 30th January 2012, 12:04 AM   #151
Who makes those corrugated ribbon for analysis speakers? Thank you.
Old 30th January 2012, 07:07 AM   #152
brian t is offline brian t  United Kingdom
brian t's Avatar
Hi i spent weeks buying and trying different materials for the suspension when i finally found the right one its therband gold its an exercise band as well as being the number one choice for slingshot users its expensive but its good quality and more important consistant in its manufacture as its critical the material has consistant thickness as a lot of other makes dont so do not be tempted to get a cheaper type.
Old 30th January 2012, 07:08 AM   #153
brian t's Avatar
the ribbon is the analysis one i did not need to replace it.
Old 30th January 2012, 12:34 PM   #154
Hi Brian
Beautiful work.
Which type of glue did you use to bond the rubber to the mylar?
Do you have resources for the rubber to buy online?
I have an broken Analysis Omega standing here i like to rebuild.
Rob
Old 30th January 2012, 05:27 PM   #155
brian t's Avatar
Rob, ok lets see if we can get your omega,s working again .the factory repair cost would i believe be even more expensive than mine due to increased size so lets start with what you need i presume its the suspension thats failed and the membrane itself is ok? to make it easy for you i have found some theraband on dutch ebay its item number 280534761171 12.90 euro thats what you need would help if you can post a picture of your speakers so i can advise you more accurately
Old 31st January 2012, 01:26 PM   #156
Default latest rebuild- progress
Ready to clamp diaphragm, have used about 80 meters of 4.5 mm tape weighs a ton. One row of magnets not needed. The other pictures are my latest rebuilds using the epsilon layout, the blue ones are neos the rest are ferrites. The last picture is my first and only glued one, won't be gluing anymore!! This was my first try.
HENRY
Old 31st January 2012, 01:48 PM   #157
Hi Brian
I already build a new bas panel without the rubber and that also works but maybe not as good as original.
You forgot to mention the glue.
Rob
Old 31st January 2012, 01:53 PM   #158
von Ah is offline von Ah  United States
von Ah's Avatar
Henry, you are a maniac. In the best possible way. I marvel at all your work.
Old 31st January 2012, 06:48 PM   #159
brian t's Avatar
Rob,i used loctite 406 spread a thin film of it to the edge of the rubber about 6mm wide by applying masking tape first to create a nice straight line of glue sqeeze the glue out along the rubber then immediately spread it out with a scrap piece of rubber so you end up with a narrow film of glue which has dried . remove masking tape then apply contact cement to that and film let that touchdry then join. 3m super 77 can also be used and is less messy instead of regular contact cement but you will need to mask off first.one other option which has proved succesful is after applying the 406 use double sided adhesive tape orofol or 3m i have found work fine.
Old 31st January 2012, 10:47 PM   #160
brian t's Avatar
Rob, looks like you have done a first class job on the bass panel can you give me some more detail about how you constructed it.cheers
epsilon lavardin amp help zerohead_ak47 Solid State 7 29th December 2008 05:02 PM
Midrange Analysis mbutzkies Multi-Way 4 25th May 2005 01:51 PM
noise analysis tenderland Tubes / Valves 5 29th March 2005 11:22 PM
cap analysis yldouright Parts 3 7th January 2005 01:45 AM
Need help in circuit analysis Fossil Tubes / Valves 6 23rd November 2004 07:13 AM
Copyright 1999-2017 diyAudio
