| Planars & Exotics ESL's, planars, and alternative technologies |
#131 |
Wow, those look really nice! Are you planning to run them full range?
By the way, I love your cars too. ![]() Wachara C. |
#132 |
Me too; all that great speaker design and exceptional esthetics as well.
Love your car lift too. Final tuning is always to your taste by your ear (nobody who has read threads on the subject here could believe that "flat" is some kind of God ordained virtue). But first you really have to get a good characterization of the output using trick software that avoids the fallacy of using sine waves in a room. Do you have good software for mic testing? I use REW from Home Theater: free, good features, and works with Macs. You need a Radio Shack sound level meter (and download the calibration correction curve for it) and away you go. You might consider testing in a few different rooms (such as garage) and also esp. open air. Run a curve on your amp output when connected to the speakers to ensure that your electric drive is flat (which can be done by just spot checking a few sine-wave freqs... but more fun with REW or other automated plotting). Which leads next to experimenting with room placement and working with multiple subs in heterogeneous locations. My Dayton-Wrights are champs for low freq and not bad down to 80 or so... with 40 lb transformers, gas, very big..... Earlier you were aiming for crossing over at like 250? If you can get down low enough to just need subs (120 Hz, no kidding), that would be great. Ben
Dennesen ESL tweets, Dayton-Wright ESL (110-3200Hz), mixed-bass Klipschorn w/param EQ plus giant OB using 1960's Stephens woofer HiFi aspirations since 1956 Last edited by bentoronto; 7th August 2012 at 09:04 AM. |
#133 |
With good transformers, you can certainly go full range on these. I really like your design.
Wachara C. |
#134 |
As stated in my last post I won't be able to get around to setting these up in the house and doing some tests for a couple more weeks. In the mean time they are hooked up in the garage to a small 40 watts/channel amp and my Ipod and they sound great. But I have noticed that I'm getting a strong ozone smell from the tweeter panels if I stick my nose right up to them. The large panels are biased to -4500 volts and the small panels are biased at -3500 volts. There is no evidence of arcing and no static or popping noises. Should I be concerned about the ozone?
#135 |
Ooops. Ozone generation may be very important to address. I hope others will bring their tech diagnostic experience to bear. For example, if it arises from sparking (which might be visible in the dark), not healthy for your diaphragm. (I think Dayton-Wrights in gas bag run much higher voltages.)
I'd just like to say that ozone is damaging for lungs, rubber, etc. when concentrated. But the threshold for smelling it is way below the danger threshold (x10). Good thing, eh. Ben
Dennesen ESL tweets, Dayton-Wright ESL (110-3200Hz), mixed-bass Klipschorn w/param EQ plus giant OB using 1960's Stephens woofer HiFi aspirations since 1956 Last edited by bentoronto; 10th August 2012 at 12:11 AM. |
#136 | |
#137 |
Long and hard to follow history on high voltage ion generators and electrostatic cleaners. Suffice it to say, they are definitely out of style today. For the moment.
Take care. Ozone bad and some research says city-living already produces too much ozone exposure. Maybe enclosing speakers is ultimately needed. And on the other hand, Mike Wright said sound output (for a given input voltage) rises with the square (or more) of the bias voltage. For many ESLs getting enough output matters a lot. I think a sensible trade-off favors conservative bias and bigger drive signal. Ben
Dennesen ESL tweets, Dayton-Wright ESL (110-3200Hz), mixed-bass Klipschorn w/param EQ plus giant OB using 1960's Stephens woofer HiFi aspirations since 1956 Last edited by bentoronto; 10th August 2012 at 11:53 AM. |
#138 |
Time for an update. In testing the speakers I ran into a problem with one of my large panels not putting out any bass and buzzing at high volume levels. It took a while to figure out the problem, but when I did I felt like an idiot. I forgot to take the protective strip off of one of the foam tape horizontal dividers.
After taking the panel apart and rebuilding it everything is fine now. I have them hooked up to my two spare QSC RMX850 amps with a Beheringer DCX2496 crossover/processor. The crossover is set to 401hz at 48 db/octave and the low frequencys are rolled off at 70 hz at 48db/oct. I've settled on these transformers for the bass: Transformer - Hammond, Output, Push-Pull, 100 W | Antique Electronic Supply LLC These are hooked up two per channel, series/parallel. And they work great. Some preliminary testing to adjust the DCX2496 show the frequency response esentially flat from 70 hz up to 20 khz. The speakers sound absolutly wonderful and can play extremely loud. Once I get them into the house I'll post some more pictures and some plots. I'm a happy camper.
#139 |
Fperra,
Pics from photobucket are not loading for me. Can you attach them as attachments in a post, so that they remain permanent? Thanks! |
#140 |
| Has anybody made an ELS headphone? | chinsettawong | Headphone Systems | 435 | 21st December 2012 09:16 AM |
| ELS Construction Questions | fperra | Planars & Exotics | 7 | 17th October 2011 01:01 AM |
| Metronome style design for multiple drivers, a number of design questions | mountainhick | Multi-Way | 5 | 28th January 2010 03:31 AM |
| Curved ELS panels | Johan_Ch | Planars & Exotics | 4 | 2nd November 2007 08:20 AM |
| Final 0.3 els | systema | Planars & Exotics | 14 | 14th May 2006 04:10 PM |
