| Planars & Exotics ESL's, planars, and alternative technologies |
#31 | |
#32 |
Suppliers for ESL parts in Germany or The Netherlands?
I try to order the most basic things like a membrane and coating material and end up with Australian suppliers of in China :-) Not to mention I found : “Mylar(R) is the registered trademark owned by the E.I. Dupont Corporation for Bi-Axially Oriented Polyester Film. There are dozens of different types and grades of Mylar(R), however the term is generically used to describe a range of different films.” Can someone help me with what type of Mylar I exactly need for an ESL? Since I found that some specialist in Australia has 3.5 micron which gives the best performance, I am looking for that thickness and give or take 600mm wide. Edmund |
#33 | |
One coat of the spray leaves a 2-micron thick film that's almost clear. Since it dries that thin and light, I don't see any need to try and dilute it or spread it thinner to save mass, as some are want to do. This is my preference.
http://jazzman-esl-page.blogspot.com/ Last edited by CharlieM; 19th February 2013 at 03:54 PM. |
#34 |
Mylar type C is used for capacitors and electronic
Great choice but hard to find in wide widths. Mylar type D is typically used for books and print coverings and is more commonly available. It is a very transparent type of mylar There many different types and some that have a heat sensitive glue backings such as model airplane coverings like Monokote and on some wrapped food products like you find on the top of TV dinners. I am not sure but the R type that you have mentioned may be a reflective type, commonly used for reflective window coverings and such as well as antistatic bags and mylar balloons. Don't quote me on this though as I have not found this label listing on the Dupont site yet. Film Type Selector Typically you want a mylar that is tensilized or has already been pre-stretched. tensilized mylar - Google Search As mylar will keep stretching up to a point then it will stop stretching. This could cause the panel to lose its tension in time if it is not a tensilized type and would have to be re-tensioned. This can easily be dealt with if you are using a mechanical stretcher by doing a test on a sample and making note on how far your sample can be stretched before breakage. Typically that would be about 2%. But a un-tensilized type may be able to stretch by as much as 4% or more before it stops stretching depending on its gauge of thickness. jer
#35 | |
No need to look in china or australia. Check out the ESL-club in your own country. You will find me there ![]() Greetings from Holland
drs M.J. Dijkstra |
#36 | |
Greetings from the Netherlands again :-) |
#37 |
So many dutch esl builders on this forum
must be because where ought to be people that don't like to spend money, so better build ur own
#38 | |
I build my own because i think i could do "better". And really good esl transformers are not normally available so i decided to build my own transformer too. |
| how to combine Line array and transmission line together | Jared | Multi-Way | 7 | 15th December 2012 01:20 PM |
| Transmission line ? | MykeysToy | Multi-Way | 64 | 15th November 2009 07:06 PM |
| line array + transmission line ? | zobsky | Multi-Way | 12 | 16th August 2006 04:18 PM |
| Transmission Line for or against? | DJ Sense | Full Range | 5 | 10th June 2006 08:35 AM |
| transmission line | boister77 | Car Audio | 2 | 20th September 2004 02:06 PM |
