| Planars & Exotics ESL's, planars, and alternative technologies |
I'm getting ready to build myself a couple of ELS speakers and would like to use the inner tube method for tensioning. I'm thinking of building my panels with perf steel 15" wide by 54" tall. Can I get a bike tire large enough for this size? My design will be very similar to Jazzman's, but with 2 10" woofers per side.
#2 |
I doubt that you will be able to find any inner tyre of that size.
#3 |
That's what I'm thinking. So far the largest I can find is 29" in diameter. I don't think I could stretch that over the film stretching jig.
#4 | |
Evidently some people have had success gluing inner tubes together for larger stretching tables. Building question - Panel Matching Building question - Panel Matching If you want to use mechanical stretching for tensioning your diaphragm, another option is to use the tape + fish scale method that ER audio uses. Here is a blog with a good writeup on the method. Jason's DIY Audio: DIY Electrostatic Loudspeakers / ESLs - The Diaphragms Alternatively, you can use heat to shrink the diaphragm after attaching it to the frame. |
#5 |
two bicycle balloon, crude rubber, cut two, put one on another
Building question - Panel Matching - this link - fully correct
Hare Krichna! Hare Rama! Last edited by Kontra; 16th October 2011 at 05:58 PM. |
#6 |
Thanks for the info. I was thinking of giving that a try. Any links to wire stator construction. I made some electrostatics quite a few years ago from Sanders' original article in the Audio Amateur with the perforated steel stators. I still have 4 of the output transformes he recommended in that article. I might stick with the pef steel stators, but will also consider giving wire stators a try if I can come up with a simple jig for wire spacing. Magnet wire would seem a good choice.
#7 |
I had Made some stators using some TIG wire and what did was I made a comb using the same TIG wire to hold the longer pieces in place while I soldered in the supporting braces.
I have not finished these yet but atleast the stators are done.
#8 |
This is an approach I used with magnet wire, for what it's worth:
Christening a new ESL wire stretcher Few |
| Cabinet Wall Construction Questions | Loren42 | Multi-Way | 16 | 1st March 2010 02:05 PM |
| BIB questions (construction and otherwise) | crappyjones123 | Full Range | 11 | 23rd August 2009 06:14 PM |
| Construction Questions | bluegti | Full Range | 1 | 28th April 2006 04:54 PM |
| Construction questions | TonyW | Multi-Way | 3 | 16th June 2005 03:29 AM |
| Orion Construction Questions | ¿GotJazz? | Multi-Way | 3 | 6th October 2004 04:44 PM |
| Page generated in 0.10584 seconds (77.99% PHP - 22.01% MySQL) with 11 queries |
