Acoustat Mods - Page 3 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 9th October 2011, 09:26 PM   #21
Mathieu: I will be at my storage locker tomorrow will see if the parts are close to the front. In the mean time I will share a mod which sounds very silly but works extreemly well. Get some galvanized screen with about 1 cm openings the kind which has all the wire overlap points soldered so there is no buzz or rattle. Cut pieces largre enough to cover the full outside surface of each panel. use some tale and some small amount of foam to space the wire mesh just off of the plastic louvre so it cannot buzz. solder a length of insulated wire small gage is fine to the screen and ground them. Place the screen on both both sides of your panels. This will take about three days to fully have effect. Easy to do fully reversible give it a try. Best regards Moray James.
moray james
Old 10th October 2011, 09:17 PM   #22
Default another mod ?
Moray,
If I catch it well :
- Prepare 4 galvanized screens for one 1+1 speaker
- Remove the cloth
- Glue the galvanized screen connected to the ground on eaceh side of the pannels.
Then the pannels are 'screened'... Have you any clue of the way it improves the pannels operation ?
Regards and thanks again to look into your 'old' stock,
Mathieu
Old 11th October 2011, 03:43 AM   #23
well my best guess is that the grounded grid or screen bleeds charge build up in the plastic louvre structure. That would account for the fact that the full effect takes two to three days to fully come around. You catch it very well so please do give it a try. Best regards Moray James.
moray james
acoustat 3 Williams Audio Planars & Exotics 26 15th September 2012 06:15 PM
Acoustat Spectra 11 mods comealongtoo Planars & Exotics 1 9th June 2011 08:22 PM
acoustat help mpetteys Planars & Exotics 3 29th April 2011 05:33 PM
acoustat 2+2 mods Gram Planars & Exotics 10 9th June 2010 03:18 PM
Cheap parts for Acoustat interface mods noelm Planars & Exotics 0 23rd June 2005 05:11 AM
Copyright 1999-2017 diyAudio
