Apogee Speakers Construction - Page 12 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 29th April 2013, 12:12 AM   #111
john65b is offline john65b  United States
john65b's Avatar
The bass panels can be re-tensioned, but I do not know what the target frequency is.
The vertical wooden clamp is likely the tension clamp, and has bolt tensioners probably like those in the vids for the Duettas.
If they are that bad and unlistenable, I would go ahead and experiment a bit with re-tensioning...
All right, but apart from the sanitation, medicine, education, wine, public order, irrigation, roads, the fresh water system and public health, what have the Romans ever done for us? Life of Brian
Old 29th April 2013, 12:53 AM   #112
Davey is offline Davey  United States
John,
I've pushed the .pdf into my ftp site for a few days. The info you're interested in is in the first few pages.
http://home.comcast.net/~dreite/temp..._procedure.pdf
Dave.
Old 29th April 2013, 01:46 PM   #113
Can someone post links to appropriate vids please.
Old 29th April 2013, 04:07 PM   #114
Here is what my bad Caliper bass panel looks like. It works but makes horrible noises. It seems retensioning to the original spec should solve my problems. Also, if someone could post a link to a service manual or at least a schematic of the foil layout on the Caliper, unless they're all the same and then a generic foil layout would be nice.
Old 29th April 2013, 04:24 PM   #115
Who and why has someone made a short circuit with copper?
The one who succeeded was the one who didn't know it was impossible.
Old 29th April 2013, 04:46 PM   #116
As to the who, I have no idea, I just took the covers off a few minutes ago. I'm guessing it was a repair done by a previous owner. Are those two bottom strips supposed to connected?
Old 29th April 2013, 04:56 PM   #117
No, they are not.
The circuit is supposed to make a double run with the aluminum.
Or else You will have half the resistance of the woofer and will make the filter cross over wrongly.
Old 29th April 2013, 05:03 PM   #118
john65b's Avatar
Check the resistance of the woofer panel. I think it should be around 3.1 - 3.4 ohms. If is is incorrectly jumpered, it will read less.
Old 29th April 2013, 05:17 PM   #119
I disconnected the jumper and resistance went to open so I re-jumpered the bottom stipe to the second from the bottom strip on the straight side and now bass panel resistance is 3.1 ohms. Some parts of the panel seem much more active than others. Is it or is it not possible to re-tension this driver?
Old 29th April 2013, 05:32 PM   #120
taotao is offline taotao  Germany
I guess your foil has a break in the circuit somewhere, look under the horizontal bars on top and bottom for a small crack in the foil.
Sorry, in my opinion you have to put new foil in your speakers.
Retensioning won't do it.
Beside the crack, the foil is very uneven, plus I suppose you've got the buzz.
Asymmetric construction induced distortion in electrostatic speakers arend-jan Planars & Exotics 40 14th June 2012 04:22 PM
FS: Apogee Caliper Signature full-range ribbon speakers andyjevans Swap Meet 1 22nd September 2010 11:33 AM
Apogee crossover trombone Planars & Exotics 1 13th September 2010 09:37 PM
Apogee MPTS-1 speakers for Dummies jpuglise Multi-Way 1 20th February 2008 07:26 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
