| Planars & Exotics ESL's, planars, and alternative technologies |
the bass driver of my beloved Heil Kithara has a problem.
As seen on the photo, the glue of the central "core" is partially taking off. can anybody recommend an suitable glue for the repairment, or do I really need to buy a new driver ? thanks gebi
gebi |
#2 |
If you're confident, the thicker superglue works well, otherwise PVA wood glue will be fine. If you use PVA, just make sure you leave a small weight resting on the driver overnight whilst it sets up. I use a 24mm socket from a spanner set.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#3 |
Check all around for weak glue under the dustcap, or you'll be back fixing it again. In fact, you might as well pull it off altogether, and re-glue so you know it's OK.
| new Heil AMT type driver | Santiago53 | Planars & Exotics | 27 | 20th March 2009 08:57 AM |
| Raven vs Heil Vs compression driver | ailouros6 | Multi-Way | 24 | 12th December 2008 07:10 PM |
| Base driver to suit ESS Heil driver | gerado | Planars & Exotics | 6 | 1st August 2007 07:56 PM |
| Page generated in 0.06772 seconds (81.74% PHP - 18.26% MySQL) with 11 queries |
