Monsoon Planar Media 9 Audio System .Speaker Replacement - Page 9 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 23rd June 2013, 04:45 PM   #81
Originally Posted by Mooly View Post
Is it a burn mark, or is it discoloration due to dirt/pollutant attraction to the white plastic. Hard in a picture to get the "full picture".
If its burning then the plug should be snipped off, the socket removed and the leads safely hard wired to the PCB.
I do believe it's a burn mark. I know the pic doesn't show it well but its brownish. Also, when I pull the plug, it's as if it has some corrosion on the post but only on the side of the burn mark. Is it possible that this is the culprit? I'll solder it directly on and post my findings. Thanks for the super fast reply.
BTW, how can I go about testing the transformer? Where can I find the specs?
Thanks again
Old 23rd June 2013, 04:55 PM   #82
Mooly's Avatar
As a service tech I have come across countless plugs like that have burned but, they are always related to a high current (and often high frequency high current) conductor.
If its suspect then hard wiring has to be the first step to eliminate it as a cause of trouble.
Testing transformers... I'll be honest... this isn't a thread I've followed. Do you mean a normal mains transformer ? Just with this being the planars and exotics thread
Old 24th June 2013, 02:40 AM   #83
So, I followed Mooly's suggestion and so far so good. It's a bit late here in Miami and my neighbor below wouldn't like it if I crank it up, but volume wasn't the issue. They would crap out even at lower volume. I'm playing some Deadmau5 through them and no problem yet. Here are some pics of the job. As you can see I clipped the plug wires and removed the posts from the board. Then soldered the wires directly to the board.
Thanks for your help/ideas. I'll be back soon as I have a few projects in the works.
Old 24th June 2013, 07:02 AM   #84
Mooly's Avatar
That plug and socket does look a bit suspect in those later pictures. Lets hope its fixed.
Old 20th October 2013, 08:54 PM   #85
I'm new to the forum. I have a brand new set of PM-9's sitting in a box for the last 4 years. Didn't come with a controller (Future Shop open box clearance). I figured I would get one off manufacturer only to find out they stopped operating. My only avenues have been web searches and ebay turning up little or no results. I abandoned my search for a long time ago. I stumbled across the set this afternoon while going through the garage. I have decided to start looking again no matter how futile it seems. I have been unable to part with the system to date and I figured I'd try and get it up and running.
If anyone out there has a spare lying around or know where I can get one, I would be extremely grateful. I'm in Toronto. You can name your price.
Thanks all, I'm looking forward to being a member!
Old 31st December 2014, 05:44 PM   #86
Default monsoon planar media schematics
All these years and all the posts and so many people looking for the schematics of these monsoon planar 9 and 14 speaker systems. So here they are. I hope this helps anyone who are still trying to fix their controller or sun. I'd like part numbers in return. The micro switch on the controller in particular. Enjoy...
Old 2nd January 2015, 01:13 AM   #87
thoglette's Avatar
Default Many thanks!
Originally Posted by handrew View Post
So here they are. I hope this helps anyone who are still trying to fix their controller or su[b]. I'd like part numbers in return. The micro switch on the controller in particular. Enjoy...
Will do. Click the image to open in full size. In addition to some bad HUMMMMM someone just snapped off the connector from the puck cable. So some work to do.
I was going to just start replacing capacitors to hunt the hum but that schematic suggests a whole bunch of ways to cut the Gordian knot and reduce the workload!
#1 suspect is Vref
Last edited by thoglette; 2nd January 2015 at 01:14 AM. Reason: Add Beer. :-( + Beer => :-)
Old 21st March 2015, 12:12 PM   #88
I have a Planar 9 system with sub. Problem is the bass level is low when turned to max. Anyone have any ideas what problem may be.
Old 6th December 2015, 03:37 PM   #89
Originally Posted by planet10 View Post
I have a box of bits downstairs. eMail me.
dave
Dave,
This is an old post, but I am hoping you still have the box of parts for the Monsoon PM-9s? Like nearly everyone else, I am looking for a replacement controller. Thanks!
Old 21st December 2015, 12:52 AM   #90
thoglette's Avatar
Default MONSOON-MEDIA-9-FLAT-PLANAR-SPEAKER-SET-CONTROLER-MODULE-8-PIN
For those of you in the US there's a controller on ebay
Monsoon Media 9 Flat Planar Speaker Set Controler Module 8 Pin | eBay
Monsoon planar drivers - has anyone used 'em? Spasticteapot Planars & Exotics 16 21st May 2012 01:22 PM
monsoon planar media 7 as line array vmps Planars & Exotics 24 5th September 2009 05:23 PM
monsoon planar computer spkrs capt mike Planars & Exotics 4 29th July 2008 09:05 AM
Small Monsoon-planar speakers - any help! Spasticteapot Multi-Way 0 5th January 2007 07:23 PM
impedance of monsoon planar 9 panels knifeinthesink Planars & Exotics 0 6th August 2006 10:59 PM
Copyright 1999-2017 diyAudio
