Monsoon Planar Media 9 Audio System .Speaker Replacement - Page 7 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 31st August 2012, 12:07 PM   #61
thoglette's Avatar
Originally Posted by bachfan77 View Post
appreciate you willingness to help; however it appears that the cable is available however when you trace the cable to the control center it appears to be soldered into the board; so leads to the question how does one use a different cable to connect?
We're going to have to break out the soldering iron - either to replace the connector in the PCB or splice the cable.
Alternatively one could theoretically get the individual cable crimps out of the connector soldered to the PCB. I think that path would lead to madness.
Old 31st August 2012, 07:20 PM   #62
frugal-phile(tm)
planet10's Avatar
On the majority of these that we fixed it was the connector that broke and the fix was directly connecting the puck. If that is your problam, replacing the puck is unlikely to fix the problem (no i don't have the connection info)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 1st September 2012, 12:10 AM   #63
thoglette's Avatar
Alright, on my to-do list.
Warning:It will be fighting for priority with spouse specified items!
Old 1st September 2012, 01:19 AM   #64
frugal-phile(tm)
planet10's Avatar
Spouse usually wins
dave
Old 2nd September 2012, 01:00 PM   #65
thoglette's Avatar
black chassis earth
brown 9V in
red audio earth
orange from amp 1
yellow from amp 2
green bass out
blue to amp 1
white to amp 2
black mute out (high=on)
The little IC appears to be a dual power opamp to drive the headphones, which is also what most of the electrolitic caps are for.
L+R -> bass mixing happens here but low pass/high pass filtering appears not to happen here.
Last edited by thoglette; 2nd September 2012 at 01:03 PM. Reason: make words clearer
Old 2nd September 2012, 01:18 PM   #66
thoglette's Avatar
Ring - chassis earth
It looks like wire colour code matches pin number for the remaining signals. My probes are too large and my fingers not steady enough to be sure - I need to find a dead apple to get a female socket to test properly.
Sorry - completely back to front. Pin 1 appears to be attached to black-next-to-white down to pin 8 on brown.
Old 5th September 2012, 04:23 PM   #67
dave
hello dave,
do you have the control center for sale for monsoon planar media 9?
Old 5th September 2012, 04:44 PM   #68
frugal-phile(tm)
planet10's Avatar
Maybe, i have yet to evaluate the parts i have.
dave
Old 10th September 2012, 01:37 AM   #69
dave
sounds good; when do you think you'll be able to raid your boxes?
Old 10th September 2012, 02:55 AM   #70
frugal-phile(tm)
planet10's Avatar
Don't know. Regular paying jobs 1st.
dave
Monsoon planar drivers - has anyone used 'em? Spasticteapot Planars & Exotics 16 21st May 2012 01:22 PM
monsoon planar media 7 as line array vmps Planars & Exotics 24 5th September 2009 05:23 PM
monsoon planar computer spkrs capt mike Planars & Exotics 4 29th July 2008 09:05 AM
Small Monsoon-planar speakers - any help! Spasticteapot Multi-Way 0 5th January 2007 07:23 PM
impedance of monsoon planar 9 panels knifeinthesink Planars & Exotics 0 6th August 2006 10:59 PM
Copyright 1999-2017 diyAudio
