Monsoon Planar Media 9 Audio System .Speaker Replacement - Page 4 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 24th May 2012, 07:40 AM   #31
thoglette's Avatar
Originally Posted by planet10 View Post
One thing i note in his commentary is that the subwoofer (ie amplifiers) contribute nothing to the satelittes. Whilr the 2-way MH500 sats are fed a flat signal, the big panels are EQed below 1k to compensate for the dipole roll-off, so not just any woofer can be substituted.
dave
Ah - I have MH-500 sats as my office speaker (hanging off an airhead and stax srd-4) which are fine with the flat signal
New set is MH-700 which will need the EQ (which explains all the capacitors in the subwoofer).
I'll check the rectifier once I confirm that the power transformer and switch are working - the switch appears to have "smoked".
Old 10th June 2012, 12:54 PM   #32
thoglette's Avatar
One more question before I dive in - anyone know what the power rail voltage(s) are on this. Schematics seem to be unobtainium. I'd like to try and fire up the amp from a bench supply
Old 10th June 2012, 11:13 PM   #33
frugal-phile(tm)
planet10's Avatar
The power supply bricks are 12 or 13 VAC or 15 VDC depending on the unit. The power transformer inside the MM1000 is something like 20-0-20 AC IIRC
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th June 2012, 12:25 PM   #34
thoglette's Avatar
Thanks Dave, that gives me a voltage to start with...
Old 12th June 2012, 11:18 PM   #35
Hello
I measured my Monsoon 600's with a Fluke and it says 2.9 ohms.
The amps are under powered, I guess to spare the ribbon from premature failure.
Hope that helps.
Uncle Buck
Old 3rd July 2012, 01:39 AM   #36
thoglette's Avatar
Confirmed my PlanarMedia(tm) 9 Audio System uses 12V. It's even silk screened on to the PCB.
The best bit is that IT IS ALIVE! Satellites alone are happily running on about 250mA at low volume
Something is fried upstream of the filter cap - the 4A DC fuse was blown, there's white powdery stuff near the power switch (solid smoke?). And the mains transformer has a thermal fuse. What are the odds of all three (and maybe even the rectifier ) being dead?
Old 3rd July 2012, 12:51 PM   #37
thoglette's Avatar
Default IT IS ALIVE
IT IS ALIVE!
And just the fuse. I have to presume that a combination of old age and shock during transport were its undoing.
The sub is humming far toooo much, which I suspect will be dried out filter capacitors.
Any other known suspects?
Old 3rd July 2012, 09:29 PM   #38
frugal-phile(tm)
planet10's Avatar
Good to hear you got it going
I found my 3 boxes of monsson stuff.
dave
Old 22nd July 2012, 12:37 AM   #39
thoglette's Avatar
Currently 1v of hum on the 12V rail and about 1/4 of that on the four sub outputs. Managed to blow my last fuse (clumbsy CRO probing of the rectifier )
Given that it's a single rail amp, does anyone know if there's a rail splitter somewhere?
Old 22nd July 2012, 05:39 AM   #40
thoglette's Avatar
Default Planar 9 hum hunt update
Found a fuse, spent a while playing with it. Adding 22,000uf to the existing 6,800uf makes not one iota of difference to the hum at the output, neither in tone nor size. The hum on the power rail is smaller if less triangular.
Interestingly the mute button kills the hum but I suspect it is muting the power amp chip.
Running from a bench power supply and it still hums, just not as loudly. And that's with the input jack shorted. I suspect some pickup on the controls.
I need to check the state of the various capacitors and start measuring some values carefully but I'm a little flummoxed.
Monsoon planar drivers - has anyone used 'em? Spasticteapot Planars & Exotics 16 21st May 2012 01:22 PM
monsoon planar media 7 as line array vmps Planars & Exotics 24 5th September 2009 05:23 PM
monsoon planar computer spkrs capt mike Planars & Exotics 4 29th July 2008 09:05 AM
Small Monsoon-planar speakers - any help! Spasticteapot Multi-Way 0 5th January 2007 07:23 PM
impedance of monsoon planar 9 panels knifeinthesink Planars & Exotics 0 6th August 2006 10:59 PM
Copyright 1999-2017 diyAudio
