Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 27th July 2011, 12:47 AM   #1
Bernie7 is offline Bernie7  Singapore
Default Apogee Ribbon Repairable? Help!
My Apogee Caliper hf ribbons are open circuited through a break in the conductive layer. This happened as a result of a design flaw - the hf ribbons are spaced from their panel housing with foam bungs which rotted away over the years and deposited on the bottom loop of the ribbons. This in turn corroded away a section of the conductive aluminium layer about 3mm wide leaving the underlying kapton exposed
Is there a way to mend this electrical break on the ribbon? Since the material is aluminium on kapton I assume soldering is out of the question and some chemical means is needed to form a conductive bond between two aluminium surfaces (I can fold the ribbon to make this contact). As this is a low impedance speaker, the bond must be able to withstand high current of several amps.
Last resort is to replace the entire ribbon but this is very costly if it's available at all.
Old 27th July 2011, 12:58 AM   #2
a.wayne is offline a.wayne  United States
a.wayne's Avatar
contact graz @ Apogee speakers secondhand buying guide
Old 27th July 2011, 01:33 AM   #3
kevinkr's Avatar
Conductive paint?
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 27th July 2011, 02:05 AM   #4
I used some Circuit Works conductive silver paint to fix an open spot on my dueette's bass panels.
I used it to glue on a small jumper wire and then secure the wire to the diagphram with a small drop of silicone.
It has lasted 11 years now.
I see no reason that conductive paint would not to work if you where to use a thin coating as it is kind of thick but dries very rubbery and flexible.
I have used nickel print from mg chemicals before aswell on different things and it dries hard.
But use a sliver based one.
jer
Old 27th July 2011, 04:07 AM   #5
expert in tautology
bear's Avatar
dunno about the electrolytic corrosion issues, but it seems to me there's not much to lose here. the silver stuff will have a lower resistance, I was thinking some very thin foil (like scavanged from a film/foil cap bonded over the break with the silver paint... that would give a wide surface area for current handling, passed over to the foil by a rather thin layer of the silver paint... it will muck up the ribbon to some degree where the problem is, but since the ribbon is large it likely will me more or less meaningless in terms of listening...
_-_-bear
_-_-bear
http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
Old 30th July 2011, 02:42 AM   #6
Thanks for the good suggestions folks.
I have previously tried silver conductive paint (used in pcb repairs) but it worked only for a few weeks before it burnt out. Guess the current was too high, so may try again this time with a bigger area of contact and some way to keep the surfaces pressed together for good measure.
FS: Apogee Caliper Signature full-range ribbon speakers andyjevans Swap Meet 1 22nd September 2010 11:33 AM
WTB 4" rotatable ribbon tweeter for my Apogee hybrid monitor speaker stevenluu60 Swap Meet 0 1st December 2008 07:59 PM
speaker repairable? kanifee Multi-Way 4 2nd July 2008 07:30 PM
nakamichi cd400, repairable?? an2ny888 Car Audio 0 1st July 2008 12:07 PM
Repairable? eXn Subwoofers 10 18th February 2005 09:39 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
