Horn loaded electrostatic ?? - Page 11 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 20th April 2012, 10:53 PM   #101
bolserst's Avatar
Originally Posted by brsanko View Post
if you crossed it over at say 200hz or lower and stacked a bunch of panels together and loaded the horn to push a whole lot of air with very little diaphram excursion it should work fine.
Yup. Horn loading a stack of panels will result in reducing the excursion of the diaphragms, same is it does for a single diaphragm. So, the maximum SPL output capability will not be any greater than if you used the same number of stacked panels built with larger D/S spacing without the horn.
But, now that I think about it, one difference with the horn loaded case is that you would be able to use lower bias and drive voltages with the horn loaded stack, which would be an advantage. No higher output, but potentially an easier/safer build.
This is very similar in concept to the ESL AMT discussed here:
Electrostatic AMT?
Electrostatic AMT?
Replacing a simple ESL panel with an array of AMT pleats reduces the required excursion of each of the ESL panels which make the pleats. But, the resulting maximum SPL output capability is the same if the frontal radiating area is the same. The advantage is the ability to use lower bias and drive voltages since the excursion requirements are reduced.
Old 20th April 2012, 11:09 PM   #102
brsanko is offline brsanko  United States
brsanko's Avatar
Send a message via MSN to brsanko
How do you figure? Why wouldn't the horn increase the output SPL like it does in every other application?
PASSIONN
Old 20th April 2012, 11:11 PM   #103
brsanko's Avatar
What is AMT?
PASSIONN
Old 20th April 2012, 11:54 PM   #104
bolserst's Avatar
The horn will increase the output SPL of the ESL. But, the horn reduces the excursion(ie output) of the ESL by the same amount. So, the net gain in output capability is zero.
Perhaps reviewing post #93 will help:
AMT = Air Motion Transformer
Old 21st April 2012, 12:06 AM   #105
brsanko's Avatar
Except that the factor that limits the output SPL of the ELS is excursion so if the horn reduces excusion at the same SPL then you turn it up. It may not increase efficiency per se' but power handling and maximum output would be increased greatly.
PASSIONN
Old 21st April 2012, 12:14 AM   #106
bolserst's Avatar
Remember the factor that limits the maximum output SPL of ESLs is Force per unit area.
This is a byproduct of the physical restraint of obtainable voltage gradient in the gaps between diaphragm and stator before the air conducts and arcing or corona results.
Review post #71 and #76
Old 21st April 2012, 12:18 AM   #107
brsanko's Avatar
I see. I guess if I want the ultimate ELS speaker I'll have to go with smaller wide range panels and either a dynamic sub or or hidden larger panels.
PASSIONN
Old 21st April 2012, 02:03 AM   #108
Mark Kravchenko
mwmkravchenko's Avatar
I beg to differ on the thought that there will be no net gain from proper horn loading. A well designed horn can give you 9 db and better gain over a normal room loading. There is a gain in efficiency due to the better acoustical impedance matching of the diaphragm to the horn throat versus an open air loading.
Carry this to it's simple conclusion. Force over unit area will not change. But the effect of the same force over unit area in a horn will create a gain in acoustical output linked to the design of the horns passband and therefore possible gain.
Less movement of the diaphragm will create more acoustical pressure if the diaphragm can meet this simple requirement.
There must be enough force over unit area to overcome the greater pressure seen on the diaphragm at the horn throat.
The multiple diaphragm method will most likely solve this problem.
And it has been precisely this problem that has stalled previous attempts to successfully horn load an ESL. Overcoming the increased acoustical loading or more simply greater air pressure on the surface of the ESL membrane.
I for one think You guys may be on to something.
Mark
www.kravchenko-audio.com
Old 21st April 2012, 02:41 AM   #109
bolserst's Avatar
Hello mwmkravchenko,
I think I understand what you are getting at, let me try and restate it to check.
Suppose I have an ESL panel with 3mm excursion limit that reaches its excursion limit in the desired bandwidth at the drive voltage which produces peak force per unit area before arcing. For this example, lets say the SPL measured at 100Hz is 100dB.
Now, add a horn sized and designed to increase the airloading on the ESL placed at the horns throat by a factor of 3. The same peak drive voltage will now only provide peak diaphragm excursions of 1mm. The horn will take this 1/3 less output and provide 9.5dB of gain resulting in the same 100dB measured.
Next, stack 2 more panels behind the original one and drive it with the same voltage. Diaphragm excursion will increase to 3mm, and the measured output will now be 109.5dB. Is this what you were getting at? If so, I agree.
But, rather than stack the 2 additional panels behind the first and adding a large horn, you could simple place the 2 additional panels to the left and the right of the original. The excursion of all 3 panels would be 3mm and the measured SPL would 109.5dB. The width would probably be similar or smaller than the horn and the construction much simpler.
Old 21st April 2012, 02:59 AM   #110
I was just going over that in my thinking and I would have to agree with you on that one,bolserst.
The ideas that I had concerning horn loading an ESL was not so much to improve gain but to help increase the dispersion angle of the panel to help reduce the beaming effect at the higher end of its bandwidth.
A 4" or 3" wide panel is not that bad at all but if you increase the width to 6" to 10" the problem becomes very prominent as you increase the width of the panel.
I know that we have discussed many different methods to combat this issue,But I am still curious as to if a horn might be a viable alternative at least for the midrange frequency's and up.
jer
Front loaded and back loaded horn DrWoofer.com Subwoofers 14 12th April 2016 08:32 PM
rear loaded horn farriswheel Car Audio 2 27th July 2007 05:03 AM
Rear Loaded Horn David R. Carlso Full Range 3 9th January 2006 10:04 PM
Need help with horn-loaded sub slicemaster101 Multi-Way 26 17th September 2002 01:09 PM
Copyright 1999-2017 diyAudio
