| Planars & Exotics ESL's, planars, and alternative technologies |
#21 |
Another stupid question I didnīt stumble upon an answer so far...
Does it matter to use either single conductor wire or stranded wire? Any difference in the magnetostatic field strenght? Stefan |
#22 | |
But, for the same gauge, solid wire will be stiffer and allow you to use fewer crossbars spaced further apart. Fewer glue joints and a more open stator frame
#23 |
Did anyone try enamelled copper wire so far? Would the the electric strength be big enough?
Have a nice weekend, Stefan |
#24 |
Well, I thought about that as well, but wouldn't the enamell crack when stretching the wire?????
drs M.J. Dijkstra |
#25 | |
wire stator design But it can be done if you are careful as moray james has shown. I believe he used 30 gauge magnet wire spaced 24 wires per inch on Acoustat style stator frames. How to construct a cube louver (Acoustat) How to construct a cube louver (Acoustat) |
#26 |
I have tested Kynar coverd wire wrap wire with great results of no arc through to above 10kv.
But I haven't built a panel with it yet,when I was going to try then prices started to skyrocket back in 03 and 04. As I used to get rolls of it fairley cheap at Radio Shack,But not any more! jer |
| how can test the stator insulation and mylar coating? | lutherblisset | Planars & Exotics | 54 | 20th January 2012 12:05 AM |
| Role of ESL stator insulation? | Few | Planars & Exotics | 22 | 8th November 2009 12:30 AM |
| Electric field and stator hole alignment | arend-jan | Planars & Exotics | 22 | 23rd July 2009 07:17 PM |
| Testing Stator Insulation | bshaw147 | Planars & Exotics | 7 | 28th August 2008 09:05 AM |
| DIY Electrostatic Stator insulation | schpeltor | Planars & Exotics | 7 | 13th February 2002 07:11 PM |
| Page generated in 0.08090 seconds (81.51% PHP - 18.49% MySQL) with 11 queries |
