Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 8th April 2011, 05:20 PM   #31
kavermei's Avatar
Send a message via MSN to kavermei
Oil burner ignition trafos, really?? I never would've thought of that... I like the idea!!
I wonder, do they have a magnetic shunt like neon sign transformers (for limiting the short-circuit current)...? I guess not, given their purpose. Good!
Do they get hot?
Kenneth
Never send a human to do a machine's job. --Agent Smith
Old 8th April 2011, 08:51 PM   #32
SM7UYJ is offline SM7UYJ  Sweden
SM7UYJ's Avatar
I do not think there is any shunt, and as they are marked "Intermitent - use only 30% off 3min cycle" - I would guess not!
I've only tested them, so I do not know if they run hot - will do some more tests during this weekend!
Roger
The probability of someone watching you is proportional to the stupidity of your action.
- A. Kindsvater
Old 8th April 2011, 10:56 PM   #33
bolserst's Avatar
I believe oil burner transformers come in 3 different types.
1) the heaviest/oldest ones are not current limited.
2) but, some models are current limited with a magnetic shunt, (20mA - 40mA usually).
3) the most recent/cheapest models are solid state(transformer replacements) and are not usable for ESL step-up transformers.
My guess would be if they say "intermittent use" they are probable not current limited.
But since you will only be applying at most 30Vrms - 40Vrms to the 220V winding you shouldn't run into any overheating problems.
With their high leakage inductance and primary winding resistance they should provide a nicely damped low pass filter for bass panels without needing any additional parts
Old 9th April 2011, 06:15 PM   #34
kavermei's Avatar
Thanks for the information Bolserst.
As I feared... Microwave oven transformers are going the same direction. (Not that they're much use for audio anyway.)
Kenneth
Old 10th April 2011, 07:26 AM   #35
Ya know? I did touch on the Idea of using an MOT last year. jer
Old 11th April 2011, 12:09 AM   #36
Also MOT's generaly only have a stepup ratio of 1:20 to 1:25.
And of all of the ones that I have tore apart I yet to have two Identical transformers.
Never the less it is still a good Idea. jer
Where you buy iron transformer core for DIY audio transformer tarsik Tubes / Valves 10 27th December 2011 08:15 PM
Changing bass amp output transformer Leb Tubes / Valves 8 27th September 2010 10:28 PM
Wind my own output transformer for 100w bass amp audiojerk Tubes / Valves 18 16th May 2008 02:35 PM
need Acoustat bass transformer... moray james Planars & Exotics 2 15th February 2007 07:22 PM
chip recomendation for a bass guitar amp (already got a transformer). facundonu Chip Amps 1 25th October 2006 06:55 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
