| Planars & Exotics ESL's, planars, and alternative technologies |
#21 |
Well, IMO ,go for price per (/) material volume per (/) field strength vs surface area /
I hope I (said that right) I figured out a formula for capacitors aswell. farads / voltage / price The lower the better. Been a while since I figured that one out Anyway the most density for the price of course. stacking them is like putting batteries in series .jer Last edited by geraldfryjr; 19th March 2011 at 11:10 PM. |
#22 |
i just found a product that may be of interest for making diaphrams
Chemtronics | Workshop Consumables | Adhesives, Sealants and Tapes | PCB Compounds and Adhesives | Conductive Adhesives-PCB Compounds and Adhesives |CW2900 it is a conductive silver paint pen ,it could be used to draw nice tracks on a mylar ribbon from top to bottom instead of glueing aluminium to the maylar heres another RS | Workshop Consumables | Adhesives, Sealants and Tapes | PCB Compounds and Adhesives | Conductive Adhesives-PCB Compounds and Adhesives if conductive enough you could simply lay out your mylar and draw your tracks top to bottom ,it would only work for a segmented ribbon though and i,m not sure how it would hold up to corrigating cheers sheafer |
#23 |
#24 |
The last time I bought one of those pen's was in 1992 for $14.95 from MCM.
The second one was in 1996 for $17.95. At that time I thought the price was absurd. Luckely it was still good in 2001 and when I repaired my apogee panel. jer |
#25 |
I still have some nickel print from M.G chemecals that I paid $8.95 a bottle in 2003 from cannada.
shipping was almost double. jer Last edited by geraldfryjr; 20th March 2011 at 01:26 AM. |
#26 |
hi jer
so how were your results ? there are many other types of paint i have found now seems like an easy way although getting a pen with a tip of around 5mm may be hard would work well with say a ribbon of 1.2m long by 50mm wide with say 9 5mm tracks with 1mm spacing between cheers sheafer |
#27 |
Well, it seems that nothing(likes to) sticks to mylar. jer
#28 |
Have you not tried this?
#29 |
hi jer
yes i have built a couple of esl speakers and there are a few products that stick quite well polyureathane glue being one of them one of the silver pens i provided a link to specificly mentions mylar ans flex circuits so i think its workable longevity is unknown though as the ribbon will constantly be moving cheers |
#30 |
Oh, Okay. I found that the stuff is very flexible and I have even been able to solder too it but it is very tricky.
I also tried to use it as a base to plate copper .jer |
| Silver Foil Paper in Oil Caps | precisioncaps | Vendor's Bazaar | 0 | 11th March 2007 02:12 PM |
| Bonding silver foil to PTFE | Nixie | Everything Else | 29 | 20th January 2007 09:54 PM |
| Looking for Ribbon foil | SQFan | Planars & Exotics | 5 | 14th July 2006 07:43 AM |
| Mundorf Silver-oil VS Jensen copper foil | 100db | Tubes / Valves | 24 | 5th March 2006 02:12 AM |
