How to make a good transformer for ribbon tweeter? - Page 12 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 6th July 2014, 06:02 PM   #111
tyu is offline tyu  United States
Thanks for all the info an cool pic........ on the ribbons&tranfourmers..............i now well pull out my Apogee Stages an Centau Minors......same 26" MT ribbons.....No transfourmers needed..........justsaying
keep up the good work...........
Old 6th July 2014, 06:31 PM   #112
ghemml is offline ghemml  Singapore
ghemml's Avatar
Old 25th July 2014, 09:53 AM   #113
Very Nice Build !!!
jer
Old 4th August 2014, 03:39 PM   #114
JonasKarud's Avatar
I have problems with my ribbons, see avatar.
When I play loud, there happens something at the ribbon connection points.
The volumes goes down, and the only remedy is to dismount ribbon and polish the connection copper plates.
Maybe I must change the copper for gold?
Old 4th August 2014, 07:40 PM   #115
If i am right you ribbon is prue Alumimum some say the best......................Apogee on my stages capton back ribbon for MT..... let the magnet stop at about a 1/2" obove the ribbon connection point .....cooling down point an no move ment.........then latter thay let the magnets go all the way down .... then added a suspensions point in the lower middel of the ribbon............go to the site some info
good luck
http://www.apogeespeakers.com/manual...eplacement.pdf
Old 4th August 2014, 07:42 PM   #116
rayma is offline rayma  United States
Maybe the copper near the connection could be tinned or gold plated.
Or, is the connection just getting loose - could it be soldered instead?
Old 4th August 2014, 08:36 PM   #117
Alu. has an oxide layer on it and this layer is highly insulating.
Have you tried scuffing up the Alu, at the connections as well.
As this may be a bit difficult to do depend on the thickness of your material you can also try removing the oxide layer with a weak solution of Sodium Hydroxide at the connection ends.
I have had similar issues before when using Alu window screen for for my ESL stators as well as connections to the diaphragm using Alu. tape.
So now I soak the screens in the solution (Etching) as this guaranties a positive connection to all of the wires in the mesh before I coat them using only a few wires for connections from the woven mesh.
This works good and I use good ole steel wool to scuff up the Alu. tape parts, these connections have now lasted for at least 10 years or so without any issues as tested.
I few of my panels would not even work at all at First try or just worked for a little while and intermittently , until I had removed the oxide layer and that was at very high voltages too!!!
FWIW
jer
Old 5th August 2014, 08:34 AM   #118
The copper aluminium interface will corrode in the presence of moisture.
After the coper and aluminium faces have been cleaned, is there a way to keep the air out of the interface? Conductive grease maybe?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 5th August 2014, 09:11 AM   #119
JonasKarud's Avatar
Ok, thanks.
I will try this one, for a start:
Silver Conductive Pen | MG Chemicals
Old 5th August 2014, 02:26 PM   #120
Atom666 is offline Atom666  Canada
Atom666's Avatar
If I remember correctly the solution suggested on the Bass DIY list from years ago for the Carver ribbons which had the same copper/aluminum connection was Vaseline.
Why not a ribbon tweeter instead of a horn tweeter? Curly Woods Full Range 9 15th July 2009 05:09 PM
Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate lduarte1973 Multi-Way 3 16th June 2009 09:50 AM
looking for good mid woofer to use with Ribbon Tweeter. samsagaz Multi-Way 32 29th October 2004 05:33 AM
good ribbon tweeter caz Multi-Way 5 22nd May 2004 02:08 AM
Titanium tweeter vs Ribbon tweeter goldyrathore Multi-Way 14 17th May 2004 08:21 PM
Copyright ©1999-2017 diyAudio
