Acoustat Answer Man is here - Page 19 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 5th December 2011, 02:03 PM   #181
MrAcoustat's Avatar
Originally Posted by Atom66 View Post
Hi
Anyone know if there are drawings of the Acoustat X,Monitor 3/4 frames available anywhere?
Andrew
Hi Atom66 you may download owners manual - service manual - schematic - brochures - and more info HERE
Acoustat
Chord CPM-2600 amplifier - Chord One cd player - Acoustat 1+1 speakers -
Life without Acoustat is possible BUT senseless.
Old 5th December 2011, 02:15 PM   #182
Atom66 is offline Atom66  Canada
Hi
Already tried there . Not on that site or the CD of Acoustat info they offer
Andrew
Old 5th December 2011, 02:20 PM   #183
john dozier's Avatar
Having owned a pair of X'x, I can tell you that they were not very sturdy. Seemed to resonate quite a bit. I would not duplicate them, but design something more rigid. The outer panels were at a slight angle to the center on the 3 panel model. Regards
Evil looms. Cowboy up. Kill it. Get Paid.
Old 5th December 2011, 05:23 PM   #184
AcoustatAnswerMan's Avatar
Hi
Andrew
To the best of my knowledge, there are no drawings available for any of the frames except for the Spectra series. And the only reason they exist is 'cause I drew 'em in Autocad, and saved copies when I left Acoustat. They are on the Acoustat CD available from the Audiocircuit.
Acoustat wasn't real big on documentation, and it's possible that drawings never did exist for the early frames. Or if they did, they were discarded when the models went out-of-production. When I joined Acoustat (at the point of acquisition by the David Hafler Co) I tried to create good documentation for the new models that we built. The surviving documentation for the earlier models is mostly limited to the owner's manuals.
Old 6th December 2011, 05:36 PM   #185
Hello, all
I am planning a system using a Cogent Research SPI that requires 4 identical loudspeakers arrayed in front of the listener at 30 degrees separation. I have 2 Acoustat Model 4 donor speakers, and because of ceiling height reasons, can't construct 4 1+1s from them. So my questions to the group are these: should I just build a set of 4 Model 1 full-range clones, or go for a double wide Model 2 lay out? Also, the only interfaces I have are a set of 4 from a pair Model 6s, a pair from the 4s (non-Medallion) and a pair from some 1+1s (blue Medallion) -- which interfaces do you recommend? I will be using stereo subs below 80-100 Hz or so and have 7 channels of 100W amplification.
My primary goal is precise imaging. My room is 17' x 22' with (unfortunately) 94" ceilings and the speakers will be arrayed in such a way that they face one of the longer walls.
Thanks for any and all suggestions.
BTW, I listen mostly to 50s-60s jazz, some classical symphony and chamber group.
Old 6th December 2011, 08:22 PM   #186
For anyone interested, here is the patent for the SPI: Optimal sonic separator and multi-channel forward imaging system
Old 6th December 2011, 10:18 PM   #187
I'll try to post pics and dimensions of two bare Model 3 frames i have sitting here.
Old 7th December 2011, 12:42 PM   #188
tyu is offline tyu  United States
Default Acoustat panels
I have had the Xs with the stock sevos tube amps1,2,3,4,1+1,2+2s....1100,4400...the 6600 in a big room...WOW!.. Have had 20-9" panels over the years An just pulled out the tranfourmers 4bias..5 T1 4T2....the 2+2 with the Apogee hi-mid Ribbions...an i will say the the M3...or 3,9" panels work the best in any room an i think sound best with the 121 a,b,c interface....ezeer to drive,great bass...all round full rang ESL sound...can be Full rich an sweet... I think the 3s let you see what Acoustats sound like.... Here a older pr M3s....an look at these NEW 6600at the fac...Other well fill diff..
Just my 2cent
Old 7th December 2011, 01:00 PM   #189
Thanks that would help a great deal.
Andrew
Old 7th December 2011, 04:39 PM   #190
MrAcoustat's Avatar
Default Another mod
monday november 28th my friend Jocelyn is at my home to replace the capacitors in my Acoustat's, 4 Audience Auricaps 5000v will be replacing my older ASC's, after about 50 hours of playing time i am very satisfied with the result, smoother & more detailed highs also more body in the bass.
No answer Antoni D The Lounge 2 13th February 2011 06:19 AM
need a tech to answer this one pks71 Car Audio 1 19th November 2004 11:50 AM
Copyright 1999-2017 diyAudio
