Acoustat 1+1 high sound level limits
As most of you in this part of the forum, I love the sound of ESL. But my Acoustats have only one defect : they cannot stand high pressure levels.
As i'm cautious (I live in France, so I cannot afford me to blow the panels), I'm using 2,5A fuses, plus the 1+1 are filtered 6db/oct with a 0.04µF capacitor at the power amps in. The low frequencies are given to a 46cm JBL subwofer with separate amp and active filter.
I tried bigger fuses (5A), but the big MK121 resistor almost melted, and I was afraid for the pannels.
Each time I'm listening loud, the fuses are blowing.
And if I've got a party with dancing music, I buy 10 fuses before, because they blow everytime... Now i use a pair of JBL for the parties.
But it make me a little bit frustrated on lyrics, high female voice levels make the fuses blowing too. Is that something unavoidable with these speakers ?
Mathieu
Sounds like you are clipping your amplifiers.
The 1+1s do have an SPL limitation, but you also need a LOT of voltage swing from the amp.
A 200 watt amp will get you to pretty darn loud, but if you have a large room and stuff it with people and try to crank out dance tunes, ur probably going to exceed the limits... I took the fuses out of mine years ago and have never melted anything... but I never tried to blow my eardrums out either - otoh I have played live rock via a mixer with no limiting and we monitored our playing (E-drums, bass, two guitars, vocals) only with a set of Acoustat 4s... more cells than the 1+1 by 100%, but still... (the room is/was 30ft x 14ft x 8ft ceiling)
The power level at 2.5amps is P = I ^2 * R which is P = 6.25 * 6ohms = 37.5 watts. The impedance of the Acoustats tends to be about 6 ohms... so at 5 amps you have 25 * 6 = 150watts. (if it is 8 ohms you made 200watts)
So, if you want to reach the 200 watt equivalent voltage swing you need more than a 5 amp fuse in there... fwiw. Of course if you are clipping the amps, best to not put more in...
ALSO, the speaker is a moderately capacitive load, so the amp needs to also be stable and able to drive such a load, not all can - especially cheaper amps and receivers...
I suggest a solid, real world 200 watts plus amplifier - you need the voltage swing, not so much high current.
_-_-bear
hi,
I join this topic for a slightly different problem, sorry.I use Spectra 11 speakers with Caso S80 tube amp. I can't exceed about 1/6th of the volume (very dirty sound at higher level), well a lot of power available... With my old Perreaux 200w solid, I used to listen at full amp level . Is there any improvement for these speakers? Maybe could i add a subwoofer but without another amp. (how,wich one?). Trying to reach high sound levels, the low frequencies are damaged first, then the mid range.
PS: Mathieu I will send you pm
what fuses? At the inlet of Your amp, In the supply lines of the amplifier circuits? From what Bear writes it might also be some fuses in the input of the ESL itself?
Anyway Bear´s calculation describes the best case, a power calculation into a resistor as load. In this case power is lowest. As soon as there is a inductive or capacitive part in the load, the power is higher, because besides the ´real´ power which is usable for acoustic output there´s a imaginary part. The amount of the imaginary part increases with the phase shift it introduces. At 45° of phaseshift real and imaginary part already equal.
This means that the amplifier has to deal with 41% more power than the speaker could translate into acoustic power. Now if You look at the impedance plots of ESLs many of them feature the highest phaseshift and rather low ohmic values in the upper midrange, just in the freq-range of high pitched female voices. This might lead to overload when driving the amps hard.
A second factor might be as Bear already suggested the amps capability to remain stable under capacitive loading. It could well be that Your amp is right at the rim, close to the onset of oscillation. It can´t follow the signal as precise as required, but adds some post ringing.
A amplifier driven close to its limits will sound harsh and stressed.
Choosing a fuse bigger doesn´t improve things in such a case but asks for serious defecting of the electronics.
Choosing a stable working amplifier is the best safety and sonic measurement....or a different speaker if You want to party.
jauu
Calvin
Google does not reveal what a Caso S80 amplifier might be.
I think you are confusing the position of the volume control for the power output of the amplifier - they are not related at all.
Calvin, the Acoustat interface fuses the speaker input line... fyi. They also fuse the PS.
The other possibility is that the HV multiplier string that produces the bias voltage for the cells has malfunctioned. This would cause lower output and distortion when driven harder.
I've posted this before, but the short version is that you need to be able to solder, mark the position of the diode's polarity on the board, then remove the diodes, remove the caps and replace with suitable HV units. You want >3kv (5kv+ ideal) diodes (low amps ok) and >5kv+ ceramic NPO caps (although Z5U will work ok). The value of the caps is printed on the caps, you can go +100% and -25% on the value no problems at all. Replace them all unless you have a way to test. Will cost you about $30USD per channel worst case. Any decent Electronics repair shop can do this job for you if you present them with the HV boards from the interfaces. (open the interface, and make a drawing of the wiring to the board, desolder, remove...)
Post a picture of the interface inside if you are unsure what is what...
The Acoustat HV boards often fail now that they are >25yrs old.
The caps get leaky and kill the diodes, drag the voltage down...
If you could troubleshoot, you could replace just the bad parts, but the parts are cheap enough, and easy enough to replace... a clue is that the channels are not equal output, although that may not always happen...
_-_-bear
It looks as if I met the right people...
First, I try to answer about Casper question : I tried a Cary tube amp, without any success. It work now with Magnepan speakers in a bi-amping configuration (in the mid-upper frequencies). Not enough current for acoustats. I tried 7 amplifiers with the Acoustats, sadly burned 2 lovely Carver PM1.5 ... :bawling:
As says Bear, impedance is a key point when considering ESL. As a coincidence, I had a perraux 200W amp, together with the perreaux SM3 preamp. This is a good choice for ESL's, it heats up to cooking some eggs, but never failed.
4 years ago I found two Electrocompaniet AW180 fot a 'decent' price 🙄. I sold the Perreaux. But with a good preamp (try AR SP14) the Perreaux can be a good chice for Acoustats. If I can give an advise, look for a good second hand solid state amp with strong, clean bass, and put your monney in a very good preamp. You will not regret it.
[book=
]%[/book]
[! Bear ! Thanks for this info. This explains why fuses are blowing mostly on female voices.
I'm thinking about bi-amping of the 1+1. This would ease the amplifier work. What is your opinion, and do you know how to connect the MK121 interfaces for bi-amping ?
Secondly I will take your advise into consideration,and will change the diodes. I already changed the caps (see photos) for MKP ones with a very good result, but could'nt find the diodes. Can you advise me the references and a supplier ?
Many thanks !!!
Wrong caps - but the ones you changed MUST be of VERY HIGH VOLTAGE or they will break down. Did you save the old ones? Note the ratings - iirc like 15kv or so!!!
The caps you want to change are the ORANGE ones. Do those first, then the diodes, or both at the same time... never the diodes first. The caps failing kills the diodes... although the diodes failing might kill the caps too... 😀
The impedance of the Acoustats does not fall like most ESLs... the interface is patented and that is part of the point of it.
In the second image the big series resistor seems to be overheated and has some burn spots, hard to tell from the pix...
Biamp? Not a plan - the Acoustat does not have a "xover" as you expect - it does not have highs coming from one transformer and lows from another, they overlap by several octaves! One could bi-amp but it would be slightly tricky and it is unclear what advantage you'd have... there might be one, but it is somewhat unclear, and in the event one amp was inverting and the other wasn't you'd have real problems until you figured that out...
For the diodes try looking at an electronic distributor in your part of the world, or if you mail order from afar, almost any major USA (or British, probably German too) distributor will have diodes of a suitable PRV... you can series two diodes to get the required PIV in a pinch...
_-_-bear
Bear,
- Original caps are 0.01mF-6000V. I replaced tham with a serie/parallel arrangement of 4000V caps.
- You are right, the big resistor is somewhat burn... Needs repair...
- I'm not very familiar with the Diodes, ebent less in the high tension field.
What should I look as spares ? Nothing is written on theses...
Many thanks,
Mathieu
Bear,
Be advised that the original Acoustat cap is rated for 6000VAC.
Your series/parallel arrangement of WIMA caps are rated for 4000VDC, but only 1400VAC.
These capacitors need to withstand the high voltage audio signal produced but the step-up transformers.
Maybe this is why you have been blowing fuses?
You might contact Moray James as he sells Polypropylene caps to replace the Acoustat Polyester caps with the proper AC voltage rating.
the diodes are simple just find "high voltage" diodes. You want PRV or PIV of 5kv or more, that is all you need. Current is low. So any diode that is not expensive with that spec will do fine. The current is very low, so a 1amp rated diode is more than good. 0.5A is good too... check the usual electronics distributors. As I said you can series two 3kv diodes too... CHANGE THE CAPS!! 😀
The stock pinky finger size yellow polyester caps are about as good sounding as you are likely to find. You can always put the stock ones back in. I don't think I can remember seeing any which failed in use. But if you need some I do have some in stock. I have poly prop factory caps which were used for a while and the Mylar yellow ones. Personally I have always like the Mylar caps best.
If your panels are in good condition you can experiment with adding another stage or two to the high voltage ladder to bump up the voltage on the diaphragm. Most stock supplies don't output more than 3Kv and you can go up to 5-6Kv depending upon the condition of your panels. If you start to get arcing just back off by a stage. You want to run as much voltage on the diaphragms as you can. This will give you more level better dynamics and better bass control.
Largely on Moray's advice, I replaced all the caps & diodes in the multiplier circuit, and added two legs. It was well worth the effort. (Thanks again, MJ!) Making those changes to the interfaces yielded better dynamics and immediacy, tighter bass, with a more effortless & energetic presentation. I didn't take any measurements but they did seem to play louder than before the changes. While I wouldn't say the differences were astounding or mind-blowing, they were clearly audible and were a good improvement. These were used with a 2+2 which will play louder than a 1+1 but I have no doubt the results I had would apply to the 1+1. I ran the 2+2 full-range with a beefy Hafler DH-500 amp and never popped a fuse or arced. They played much louder than my ears could take.
Very interesting moray , is the upper limit set by the gap ? would Increasing the gap and the voltage improve the sound ?
regards,
Yes gap more or less sets the limit but in old panels dust or contamination can have an impact. You can wash your panels in the tub with a decreasing agent and then rinse 100%. Keep the panels vertical (on edge) when in fluid so as not to stress the diaphragms. You can re tension after if you like. Changing the gap means building new panels which is a good idea but I would not increase the gap more than it is, slightly smaller would be good and use a crossover and sub for far better bass than full range.
Many thanks MJ and Wayne,
MJ, can you send me the cost for caps and, if possible, a complete set of diodes, including a shipping ?
You will find my adress in my profile. Paypal suitable or whatever is ok for you, you're welcome if yo like to fly here for a visit.
Mathieu
Mathieu: I have been charging $15.00 each for the caps so $60.00 for the set of four pieces posted in a small package I would imagine $20.00 postage. My pay pal is morayjamescables@yahoo.com
I know that folks here may howl at this but for a good number of years I have been using 1N4007 generic diodes (2 in series) to replace the stock diodes and have not had a failure yet they cost pennies each use those as they are available anywhere. Best regards Moray James.
Dear Moray James,
I'll change the caps as soon as I receive them. I assume that the orange components on the board are the resistors of the High tension ladder.
3300M means 3300 Mohms. Is that correct and shall I change them too ?
Mathieu
The orange components labels 3300M would be the HV mutiplier capacitors and are 3300pF.
The are components C6 - C10 in the attached schematic.
If you are replacing them, I would recommend using caps with voltage rating of 2.5kV - 3.0kV.
FWIW, the 2 or 3 Acoustat HV supplies that I have measured are driven with about 750VAC which matches Acoustat schematics( I posted one in the previous post). This being the case, the worst case theoretical PIV voltage that the diodes would see would be 750VAC x 1.414 x 2 = 2121 Volts which, I would bet, is pretty much in the noise of the voltage ratings for two 1N4007 in series.
I reality, only the first diode in the supply will see anything close to this voltage. As you work down the chain, the PIV requirements taper off since the actual voltage stored by each capacitor that the individual diodes charge falls off the further down the multiplier you get.
All true, but in practice, the caps tend to degrade over time... there is internal migration of the conductive coating on either side of the "puck" of ceramic, this causes leakage... higher voltage caps have a fatter puck, and are more resistant to breakdown. I'd go with 5kV or higher caps.
Measuring along the multiplier the drops appear to be pretty even... about 1.5kv per, iirc...
Since it is cheap enough to get the higher voltage caps, why not? 😀
_-_-
