My 2:nd ESL-attempt - Page 17 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 4th April 2012, 12:30 AM   #161
haraldkasper's Avatar
Hallo! a quick question where in Skane (living in Flyinge) or Sweden could i buy material for stators.
Old 4th April 2012, 08:50 AM   #162
SM7UYJ is offline SM7UYJ  Sweden
SM7UYJ's Avatar
haraldkasper: Ill PM you the details!
The probability of someone watching you is proportional to the stupidity of your action.
- A. Kindsvater
Old 12th July 2012, 02:57 PM   #163
WrineX is offline WrineX  Netherlands
WrineX's Avatar
sorry to quote such old replys but
i used felt from a shop where you can get clotch and stuff for sowing, and really in my measurements it did not alter the highs at all and resonance was almost gone!!!
you do miss the transparancy of the panel witch could be a problem for some folks.
Originally Posted by bolserst View Post
Hello Wachara,
You only need to put the felt on the back of the rear stator.
The easiest way to apply the felt is with contact cement applied only around the outside edge of the rear stator, basically where the spacers run up the sides, top, and bottom between the rear stator and diaphragm.
For a quick test to decide if you like the results, you could just tape the perimeter of the felt down to the stator.
Much easier to remove and less messy than contact cement.
Also, you will find that once the bias voltage has been on for a few hours the felt will acquire a charge that will cause the felt to be attracted to the stator helping to hold it in place.
Old 14th August 2012, 03:07 PM   #164
fperra is offline fperra  United States
Roger, any updates on your speakers? Are you still using the oil burner transformers?
Old 15th August 2012, 06:59 AM   #165
SM7UYJ's Avatar
Still using the oil burner transformers, but I'm planing a major overhaul soon!
The oil burner transformers are not usable above ~175Hz and I would like to cross over to the mid/high-panel a bit higher!
I'm going to redo my basspanels with 12m film and try to wind new audiotransformers + integrate the speakers with my dipole subs ( 2x12" SLS in H-baffle).
/R
- A. Kindsvater
Old 16th August 2012, 02:58 PM   #166
/R
I'm having the same problem. Here is what the output of my burner transformers driving the bass panels looks like:
I'm hoping I can use some equalizing to level the output for a 400Hz crosover. If not, then I'll be looking for some better transformers myself.
ER Audio ESL III Kit, and ESL questions in general wixy Planars & Exotics 27 29th July 2014 11:14 PM
My ESL attempt SM7UYJ Planars & Exotics 144 4th March 2010 01:22 PM
Copyright 1999-2017 diyAudio
