My 2:nd ESL-attempt - Page 11 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 18th April 2011, 10:17 AM   #101
Lovely speakers, a job well done!
Old 18th April 2011, 10:46 AM   #102
SM7UYJ is offline SM7UYJ  Sweden
SM7UYJ's Avatar
Thank you all for the kind words!
I have only been able to play in stereo for a day and the filter is a first version - but I'm very pleased with the sound!
When listening to other systems I have mostly reflected on the "boomy" bass compared to my hybrids.
I'm sure it's because I've been listening to dipole bass for years and have trouble with boxed systems.
When I compare my new panels to my hybrids - the hybrids now sound boxed!
Roger
The probability of someone watching you is proportional to the stupidity of your action.
- A. Kindsvater
Old 18th April 2011, 11:41 AM   #103
That is exactly my thought when I first heard my Apogee's and got used to them.I kringe when i'm forced to listen to a box anymore.Although my bass system is not bad at the moment with 2-12's, 4-10's and 2-8's for subsand flat from 15hz to 1000hz.I am working out some 4 foot esl's for the rest of the range for this years project.But I can't wait till I at least get my little panels hooked back up for the time being. jer
Old 18th April 2011, 11:47 AM   #104
I don't what's up with my post as it is supposed to be a space in between each sentence. jer
Old 18th April 2011, 11:50 AM   #105
even editing would not work. jer
Old 18th April 2011, 02:35 PM   #106
chinsettawong's Avatar
Hi Roger,
I know exactly what you mean. I bought a pair of used Martin Logan Aerius a few months ago just wanting to compare the sound with my full range ESL. I found the sound of ML to be very boxy, and I didn't like it. They are now just sitting in my listening room gathering dust.
Wachara C.
Old 27th April 2011, 08:34 AM   #107
SM7UYJ's Avatar
After some listening and aligning the speakers more serious - there was trouble, -The sound stage tilted to the right !
I put on some pink noice and took a SPL measurement.
The right speaker was 3-4dB louder - not good!
To try and find the fault, I got my selfwound transformer and hooked it up seperatly to the right and then to my left panel - still 3-4dB difference!
Well, well - I'll just have to rebuild the panels in my left speaker ( this speaker was the first to be compleated and had been used to test trafos, EHTs, filters etc) -do again, do right!
Spent a half day with lamp oil peeling the panels apart and getting the foamtape off the PVC-spacers.
( Wachara: -The tape sticks like .......to PVC! )
Cleaned everything a couple off times, put on new tape and new Mylar.
With fresh panels mounted in the frames I fired upp the speakers again.
-The soundstage is still tilted to the right!
I was very confused, but the engeneer in me said that there must be a logical reason for the difference in output - and it's probably not in the panels!?
And it was'nt!
Quoting my footer, there must have been many people watching!
When you test ESL panels - test them with EXACTLY the same gear!
I used the same audio trafo as I suspected the problem to be there, but used the EHT mounted in the speaker!
I had managed to kill two diods in my left EHT-unit => the bias was abt. 600V lower on this side!
I fixed the EHT-unit and the soundstage is back to normal!
Next up is to get the XO optimized - Should I change my footer just in case?
Roger
- A. Kindsvater
Old 27th April 2011, 11:32 AM   #108
digits's Avatar
so what is the cost breakdown? Very nice stuff man.
Old 27th April 2011, 01:42 PM   #109
SM7UYJ's Avatar
Panels
Steel for stators: $185
Powdercoating stators: $100
Mylar 2m and 6m : $60
Aluminumfoil, glue etc: $50
MT-Audio coating: $10
Foam tape 1mm : $75
Frames
19mm MDF : $50
16mm MDF : $40
Black paint: $75
Stainless steel screws: $20
Rubber window seals: $20
Silicone: $10
3mm black Plexi: $150
Electronics
8 pcs 12V/240V toroids: $350
4 pcs ignition trafos: $50
2 x EHT : $100
Other
Ac filter, plug, aluminum sheet : $150
Total: $1495
Toroids, electronics and some of the other stuff I already had on my shelves, so they did not cost me.
Roger
- A. Kindsvater
Old 27th April 2011, 03:02 PM   #110
็Hi Roger,
The imbalance happens to me once. It turns out to be that my panels are very leaky and I have to redo everything.
How did you manage to burnt your diodes and still have voltage on the output?
Wachara C.
ER Audio ESL III Kit, and ESL questions in general wixy Planars & Exotics 27 29th July 2014 11:14 PM
My ESL attempt SM7UYJ Planars & Exotics 144 4th March 2010 01:22 PM
Copyright 1999-2017 diyAudio
