| Planars & Exotics ESL's, planars, and alternative technologies |
#11 | |
I will give you my opinions but I would seek other opinions as well:
http://jazzman-esl-page.blogspot.com/ Last edited by CharlieM; 31st December 2010 at 04:29 PM. |
#12 |
Thanks for the detailed response.
My initial thoughts were 1.6mm spacers and a frame so your advice is kind of already the default plan. I guess I'm just exploring another option. ![]() A 1mm steel sheet is indeed very flimsy, I was thinking the layered build with tape would transfer any bending motion/force into shear forces making the construction stiff. Yoy're probably right, a frame is probably the way to go. ![]() (Swedish terminology might not translate 100%, if I'm saying strange things please tell me and I'll try to find the correct words.) |
#13 |
I might just add a little side note...
It was the free samples of 1.1mm (43mil) VHB that got me thinking if it would be a viable option to go with the smaller d/s spacing. (I got a couple of sample rolls to try out the product...) |
#15 | |
Since I have not personally built an ESL with d/s spacing smaller than .062" (1.6mm) I can't say for sure that 1.1 mm spacing would create problems, provided that the distance between support spacers is within the 70-100x d/s guideline per Roger Sanders' ESL Cookbook (which also recommends .070" minimum [about 1.6mm] d/s spacing). It is correct to say that closer spacing gives higher efficiency because the strength of the electrostatic force falls off quadratically with distance. So, for a given power input, 1.1 d/s would yield significantly higher efficiency, within the smaller space provided for the diaphragm to move in. The question then becomes at what point and loudness the diaphragm would be driven into the stators-- and I can't answer that question. I will stick with my recommendation of 1.6 mm d/s for the reasons given in my earlier post. I can say with certainty that 1.6 mm d/s will give no problems in a hybrid panel and will yield good output too. This I know because my 30.5cm x 122cm panels with 1.6 mm d/s will play louder than I can stand to listen. One more thing, your 25cm x 165cm panels are only about 12% larger than mine so I'm thinking their 12% higher capacitance would likely not be a problem. (of course, if you use the smaller 1.1 mm d/s, the capacitance would then be substantially higher). Again, I would ask Calvin's opinion on your panels size/capacitance and d/s spacing.
http://jazzman-esl-page.blogspot.com/ |
#17 |
What's the downside to bigger spacing? Voltage is cheap but burning holes in your diaphragms sure isn't. If it is a conflict between engineering design perfection versus plain good sense, it really shouldn't be hard to decide.
Dennesen ESL tweets, Dayton-Wright ESL (110-3200Hz), mixed-bass Klipschorn w/param EQ plus giant OB using 1960's Stephens woofer HiFi aspirations since 1956 |
#18 |
In my case here the 1.6mm (0.062") option is the default option. It's tried and true.
If 1.1mm (0.045") were an option it would make my life easier. Inter-Spacer distance would be more optimal, I already have tape lying around, due to lower voltage demands a direct drive amplifier might be an option later on. Active diapraghragm width will be 200mm. Recommended inter-spacer distance is 70-100 x d/s spacing -> either 116-160mm or 77-110mm. Running a spacer down the centerline with 1.6mm d/s spacing would put me outside the recommended interval forcing me to go with horizontal spacers insted. -> Not as good for the active radiating area. -> possibly loosing efficiency/sensitivity? Voltage requirements estimate 1.6kVrms vs 1.1kVrms. 3.1kVpp might be doable with a fairly simple OTL tube amplifier. I said might... I'm just keeping my options open at this point. 4.5kVpp is a harder nut to crack. So I guess there are some incentives for me to explore the small d/s route. If it's just a plain and simple bad idea I'll drop it and not look back, but abandoning it just because it's not the normal way of doing things just isn't my style. |
#19 |
markusA:
I would go with the 1.6mm spacers! I use 2mm for my midpanel and 1mm for the tweeterpanels in my ESL-hybrids. It will be a compromise as you want to cross over to your woffer as low as possible => the need off larger d/s, small d/s => lower EHT, transformers etc. as you previous stated. With 1.6mm d/s you should have no problem getting your XO below 300Hz! Roger
The probability of someone watching you is proportional to the stupidity of your action. - A. Kindsvater |
#20 |
1.1mm is good for a maximum SPL-value of 110dB@4m for f>200Hz with my small panel. Sounds sufficient eyyh? Gives any bass a good run for the money.jauu Calvin |
| Front panel construction - help with buttons! | commoncollector | Construction Tips | 3 | 28th August 2009 05:33 AM |
| Acoustat two way esl panel | pwgtang | Planars & Exotics | 18 | 19th November 2008 05:28 PM |
| Split an esl panel to two way panel | pwgtang | Multi-Way | 1 | 13th August 2008 06:57 PM |
| Adhesive for ESL panel repair | 405man | Planars & Exotics | 1 | 29th August 2007 02:47 PM |
| Quad ESL 63 Panel Failure | Atom66 | Planars & Exotics | 2 | 22nd January 2007 12:56 PM |
