Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 13th February 2011, 06:37 PM   #31
WrineX is offline WrineX  Netherlands
i believe the tension of magnepan is really high. so stretching it then heat treat i wil become more sloppy then it whas before the heatgun action. and my bed is when the tension it to low it will wack into the magnets.
but let us know i have 4 smg's here that i wanted to do the same thing with addig esl from 300 and up let the magnepan do the thing there pretty good in, the lower octaves without havng to have panels great as doors in ur living room.
Old 13th February 2011, 07:17 PM   #32
[QUOTE=john65b;2409476]I have rewired many Magnepans, and for tweeter section rewires, I just used Copper Magnet wire from Radio Shack. Worked perfectly. Originals are aluminum, but the Copper may be a bit of an improvement if you ask me.
QUOTE]
it adds weight so its certainly not an improvment. thats the reason they use al especially the tweeter part beter be as light as possible.
you could use this tape they use in security to tape on windows. its really thin.
Old 19th January 2012, 11:52 PM   #33
john65b is offline john65b  United States
john65b's Avatar
I think the additional weight of copper wire glued to the mylar with DAP Weldwood would be far less than the aluminum wire with the 3M Super 77 spray glue and Milloxane that was stock and often recommended as a fix
"I speak Spanish to God, Italian to Women, French to Men, and German to my Horse" - Charles V
Old 20th January 2012, 12:10 AM   #34
gootee is offline gootee  United States
If you apply some DC voltage to the conductors, it and the magnets should hold the conductors in perfect position, for the glue application and curing.
Old 20th January 2012, 12:14 AM   #35
So then, of course, using aluminum wire or foil with the DAP should weigh even less. <smile>
But if the wire you used can handle the current, without heating too much, and its mass is low-enough, it should be fine.
Old 20th January 2012, 12:47 AM   #36
We did a little work on the relationships between aluminum wire and foil sizes, lengths, resistances, and weights, a while back, at:
RE: "If we replaced the wire with foil that had 1/4th the mass and 4X the resistance per inch" ... - tom_gootee - Planar Speaker Asylum (Click on the "All" link at the top, to see the rest of the posts.)
ER Audio ESL III Kit, and ESL questions in general wixy Planars & Exotics 12 7th December 2007 02:46 AM
Dutch ESL builders attention...part ESL for free Bas Horneman Swap Meet 10 14th June 2005 07:54 AM
WTB Magnepan 3.3, FS Magnepan 2.6 guyv Swap Meet 1 9th May 2002 09:32 PM
Page generated in 0.08220 seconds (78.01% PHP - 21.99% MySQL) with 11 queries
