| Planars & Exotics ESL's, planars, and alternative technologies |
How are members providing a return path for DIY ribbon drivers?
I am not satisfied with the idea of connecting wires to the top and bottom of the driver. I feel such a solution would be very susceptible to noise. In addition, this solution does not address the magnetic field generated around the return loop. Using two ribbons (current might go up in the left ribbon and down in the right ribbon) with a symmetrical magnetic circuit (ie S - ribbon UP - N ribbon DOWN - S) would provide a return path, however the coupling between the two ribbons isn't exactly ideal. They will be attracted and repelled from each other (depending on direction of current), possibly creating a rocking motion. Any thoughts?
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them." |
#2 |
The return wires are not or should not be in the magnetic loop . The wires are best ran out side of this away from the frame 1 inch apart
#3 |
yeah, with two opposite magnet fields you wont need return wires
but its wider, and maybe not what you had in mind |
#4 |
| The Return Of Blackburn Mullards? | Trout | Tubes / Valves | 167 | 18th February 2010 08:45 PM |
| Return of my differential VAS | scott wurcer | Solid State | 85 | 28th October 2009 04:09 AM |
| Where do you return your load? | rgrayton | Chip Amps | 7 | 18th October 2005 01:17 PM |
| Nelson - Return of the Claw | griff | Multi-Way | 2 | 17th April 2002 09:30 AM |
| Page generated in 0.07582 seconds (69.45% PHP - 30.55% MySQL) with 11 queries |
