Best 500Hz and down woofer for pairing with ESL? - Page 3 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 11th July 2003, 09:40 PM   #21
Wizard of Kelts
diyAudio Moderator Emeritus
If all you want the magnetic woofer to do is to go down to 100 Hz, you can compromise and build a true Infinite Baffle and make the internal volume considerably larger than the Vas. That will cut off the back wave interference, but let the woofer be essentially free-swinging, which is the essential advantage of the dipole, I think.
The Vas of a speaker designed to go down to 100 Hz shouldn't be that much. The enclosure would not be big.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 11th July 2003, 10:58 PM   #22
7V is offline 7V  United Kingdom
7V's Avatar
I'm just thinking out loud here. Bas, am I right in thinking that you would quite like a dipole if you didn't need the equalization circuitry?
The EQ is to boost the low end, isn't it? I wonder if it's possible to have a line array and tune the comb effect to lower the high end instead.
Probably wouldn't work but may just be worth having a go with the old pvconsultants - Vertical Polar Response program for line arrays.
Jim G, I see you're out there. You're the line array man. What do you think? Can the comb effect be used for the benefit of humanity?
I'm too tired right now to play it myself but if anyone thinks that there may be some mileage in the concept ...
Old 12th July 2003, 01:34 AM   #23
Ken L is offline Ken L  United States
Bas, it's all about the chosen compromises, and making sure you're choosing the right compromises for you and the system you are planning to put together.
If you want it to be worth the effort, you have to increase the budget -
If you are interested in dipoles, you've got to eqalize -
If you are interested in a line source, a fellow named Pierre Henri made a very interesting post at
http://www.audioasylum.com/forums/HU...ges/51782.html
I sent him an e-mail a couple of days ago wanting more info but as of this time he has not responded -
Bill Fitzmaurice also made an excellent post about line arrays-
You really might want to read that whole thread, it's about integrating subs with horns, but has a lot of good info relative to what you are tinking about at this point.
Last but not least here - I think you're on the right track to plan to crossover to subs at 100 HZ or so, trying to do it all with one sytem would be asking too much -
What I believe to be an important aspect for you is to incorporate that decision into this one - seperate but made jointly, if you decide about both at the same time you will have a much greater chance of success because your game plan will be more coherent.
HTH
Later
Ken L
No longer powered by Linux - not enough apps and cross platform integration - but maybe one day
Old 12th July 2003, 09:51 AM   #24
Pjotr's Avatar
Hi Bas,
Have a look at this site:
http://www.euronet.nl/users/temagm/audio/index.htm
and of course: http://www.linkwitzlab.com/
Old 13th July 2003, 02:15 AM   #25
frugal-phile(tm)
planet10's Avatar
Originally posted by sfdoddsy
Dipoles roll off at 6dB per octave below a certain point which is related to the width of the baffle, so you need to boost them by the same amount.
Or just build a big baffle ... KW essentially suggests that. The VIFA P13 is a very nice driver. Big bang for the buck. The Jordan JX150 is a couple notches up (in price too )
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th July 2003, 12:31 PM   #26
Default Might be what you have been looking for bas
For that matter, might be what I am looking for also -
Pierre-Henri just replied to my request for more info - what follows I have cut and pasted from his e-mail -
________________
Hello,
Sorry for late answering but I was in vacations for a few days.
Currently I have not many more details that what I posted, but I will meet this guy again in the summer to have more details. Then I can keep you informed. My impression is that it is the best bass I heard except very large horns. XOver was 80 Hz, 12 drivers were used in two vertical arrays of 6. It takes a strong amp to have it work OK. Bill F comments on modes correspond to what the guy told me ( he is a speaker designer ), the other important thing about this design is to have many drivers in order to have a large radiating surface and little excursion from each driver.
____________________
Very interesting, I will post any further communications from him on this subject.
Later
Ken L
Old 23rd July 2003, 08:21 AM   #27
Bas Horneman's Avatar
Thanks for all the suggestions all. Sorry for the late reply.
Just got back from holiday..
That is 100% what I was thinking. Dipole..sounds good, don't have the stomach for eq at the moment.
Good points Ken L, will have a look Pjotr...Maybe that is a good copromise..Planet10 but won't a big baffle defeat the line source type o solution?
Bas
Old 29th July 2003, 03:59 PM   #28
How about the MCM 55-1870 as used by Doc Bottlehead in his straight 8's?
Words used to describe this speaker are "Very dynamic; very fast;"
Plans can be gotten for $35 ...I'll just omit the tweeter. Driver around $10 per unit. (No secret coating recipe needed like Doc uses, as the coating is used to dampen high freq ...I'll be using them from 500Hz down)
Lemme know what you think.
Will have satisfied the line source part..plus a fast sound..to integrate with esl's ...just not dipole!
Bas
Old 29th July 2003, 06:59 PM   #29
frugal-phile(tm)
planet10's Avatar
This is a good little driver... i have used some of the sheilded version. Why buy plans, it is just a sealed box IIRC -- pretty easy to figure the box.
The best secret ingredient is just puzzlecoat. A coat on the front or the back of the cone makes it better behaved.
dave
Old 29th July 2003, 09:01 PM   #30
That straight 8 design seems to be well thought of, there was a poster over at AA-HE, who had heard both the straight 8 and Hammer Dynamics and gave the edge to the Straight 8.
This also somewhat goes along with what Pierre-Henri said about the arrays of six 10" Peerless.
This is a very attractive solution - I will probably go with double H frame dipoles in my case, because it will suit my space requirements better -
However, you never know, it looks like a good bit of time may pass before I get to that particular point.
Later
Ken L
What about using a 18" until 500Hz? hugobors Multi-Way 28 14th September 2010 04:00 PM
Pairing odd-bod Tannoy 15's? Brisso57 Full Range 1 13th November 2008 04:31 PM
Pairing the Seas Magnum with the E0045 woofer gottagettubes Multi-Way 0 5th October 2008 12:07 AM
Why don't/can't we use our (sub) woofers from 0 to ~500hz? JinMTVT Multi-Way 11 6th January 2006 04:26 AM
vifa pairing rv1890 Multi-Way 2 25th January 2005 07:21 PM
Copyright 1999-2017 diyAudio
