| Planars & Exotics ESL's, planars, and alternative technologies |
#111 |
I think that the baffle compensation is the reason for the multiple taps. I haven't measured with anything other than the 1+1 tap, but I'll bet that the first part of the curve, the dipole-cancellation part above the fundamental resonance, is what gets raised and lowered. Of course, the load is changing too as more panels are added, which interacts with the transformer ratio....
Do try to get a couple of panels as the load- I substituted some HV ceramic caps as the load and got very different results as I approached the fundamental resonant frequency of the panels (roughly 100Hz).
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#112 |
I have panels, but they were not connected to the unit.
Here are the results: Acoustat 121a interface; no load; 0 db ref 1kHz. (measured ground/CT to one leg of the secondary, both xfmrs & coupling components used) 20Hz. +7 40Hz. +7 100Hz +7 200Hz. +5 500Hz. +2 1kHz. 0 5kHz. -1 10kHz. -1.5 20kHz. -1.5 The HF pot was randomly set by the owner of the unit (it's here for repair - hv section) so that accounts for the minus figures above 1kHz. The unit was swept, I recorded approximate frequencies of interest... HP ACVTVM recorded the dB levels. I also dunked in a 0.001ufd and a 0.01ufd as a load to see... no significant change was noted. The tap was on the Model 4 setting - least "boost" via the LF xfmrs *primary* tap - I got that wrong in the earlier posts. What's a 1/4 wave at 8"? Seems higher than 150 hz., seat of the pants... _-_-bear
_-_-bear http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. -- |
#113 |
Well, the total panel width (with overhead) is about a foot. So you'd expect to see cancellation effects centered around 400-500 Hz or so.
#114 |
Oh... I will double check probably next weekend to make 100% certain that both transformers are working - it's unlikely that they are not, but still a possibility.
_-_-bear
| FET Switch Isolation using optocouplers instead of conventional gate drivers | rtarbell | Power Supplies | 8 | 4th February 2011 09:24 PM |
| Getting high SPL from electrostats. | Fanuc | Planars & Exotics | 21 | 30th January 2008 06:39 PM |
| Electrostats | bbksv | Planars & Exotics | 10 | 8th February 2004 06:45 AM |
| Subwoofer for electrostats | Adam | Subwoofers | 5 | 28th December 2001 07:56 PM |
| Page generated in 0.07916 seconds (71.45% PHP - 28.55% MySQL) with 11 queries |
