| Planars & Exotics ESL's, planars, and alternative technologies |
hi
I found some tube amp kit at RITTER electronic systems--Die Röhrenspezialisten seit 30 Jahren! I would like to drive my esl panels with some single-endet triode amp kit (V22 ,V40 ) my system is: hybrid 2 toroidal transformers 1:65 , ( 2x 230/7 50Va) regulated bias supply one speaker consists of 4 panel each 6 inch x 10 inch ( 15 x 25 cm) and one 16 x 20 inch ( 40 x 50 cm) panel ( I had spare parts so I made this additional panel and would conect all together) 60 mil d/s a tl with a peerless sls10 coated with elvamide. so but I'm not really sure which outputtransformers i should use 4 ,8, 16 ohm thank you for any help hironimo |
#2 |
there are conflicting demands -- for the woofer, 4 ohms is best (better damping factor).
For the ESL you need to know the voltage swing of the output tube and multiply that by the winding ratios of both transformers to see which one gets you closest to the voltage swing required by the ESL.
Never send a human to do a machine's job. --Agent Smith |
| Altec 806A 16 ohm to trade for 806 8A (8 ohm) diaphragms | nelsondog | Swap Meet | 0 | 7th April 2010 12:32 AM |
| PHL Bass Midrange 8 ohm vs 16 ohm - same SPL: Why ? | tiefbassuebertr | Multi-Way | 6 | 28th March 2010 06:14 PM |
| parallel wiring 16 ohm 4 ohm | tobler | Subwoofers | 3 | 21st November 2005 04:28 AM |
| Two 4 ohm woofers in series or two 16 ohm in parallel. Which is better? | Cal Weldon | Multi-Way | 16 | 21st February 2004 12:31 AM |
| Matching my 8 ohm amp to 16 ohm speakers. | DocJDG | Solid State | 3 | 5th December 2001 01:54 PM |
| Page generated in 0.06792 seconds (68.22% PHP - 31.78% MySQL) with 11 queries |
