Planar speaker - first try - Page 7 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 25th September 2010, 09:54 AM   #61
Default TMBLACK
i used 740 magnets for a pair. I get my magnets from China it works out cheaper if you buy 1000.All the other sites are dearer. Go to posting 41 for the pictures of my push pull full range planar. The 6mm and 3mm design is no louder than the 3mm 3mm design.So I will build a 6mm 6mm design to see if that is better. Got to cut the MDF glad the weather is better. $2 is very dear compared to China
HENRY
Old 28th September 2010, 03:46 AM   #62
Which magnet supplier did you use? i am very interested in this project. have you made any sound measurments of your planar?
Old 5th October 2010, 03:11 PM   #63
Default chinese magnets
Send your enquiry to this email address helen@ndmagnets.com She will give you all the details
HENRY
Old 5th October 2010, 03:14 PM   #64
The main measurements I do are by ear, although I have used a sound level meter in the past.
HENRY
Old 5th October 2010, 07:18 PM   #65
tmblack is offline tmblack  United Kingdom
Has anyone tried paper or silk instead of mylar sheet material?
Old 22nd October 2010, 03:25 PM   #66
Hi bentl
I have just got 4 rolls of alutape from CPC.When i messure 5 meters i get 0.6 ohm.That´s app. 0,1 ohms /meter.
Any progress in your planar?Have you tried to messure your tape?
Båndsei
Old 22nd October 2010, 09:26 PM   #67
bentl is offline bentl  Norway
No - have not made much progress yet due to heavy workload.
Did actually spend one hour in the the workshop this evening and got the diaphragm and tape in place
Will try to connect the conductors tomorrow and make it play!
I have not measured the tape. I aquired it by recommendation of an other forum member who have the measurements. But I am more interested in the sound than the resistance
Old 23rd October 2010, 01:04 PM   #68
Baldin is offline Baldin  Denmark
Baldin's Avatar
Send a message via MSN to Baldin
A bit slow here Alutape from CPC .... don't know CPC, any link?
Is it the kind of tape uses for alarms on windows etc?
0,1 ohm per meter seems quite low. How thick (and wide) is the alu?
Kind regards Baldin
Visit www.sensibleaudio.dk or read latest news on Baldin's Blog
Old 23rd October 2010, 01:42 PM   #69
It is app. 30my but seems to have lower resistance than the one i had.
Your Search Results | CPC
The tape is 9mm wide.
For my new speaker i will split it to 3 mm.
Old 23rd October 2010, 04:04 PM   #70
svenny is offline svenny  Canada
What is the lowest frequency you expect to get?
Full range planar speaker using neo magnets JAMESBOS Planars & Exotics 382 21st January 2017 03:53 PM
Anybody seen this type of planar speaker? WrineX Planars & Exotics 21 16th August 2015 09:28 AM
need help picking a planar speaker lochness Multi-Way 5 30th May 2007 08:42 AM
planar 25 vs planar 3 GAK Analogue Source 2 30th January 2004 03:38 PM
Copyright ©1999-2017 diyAudio
