Planar speaker - first try - Page 6 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 15th September 2010, 12:18 AM   #51
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by bentl View Post
Just a thougt;
What difference does it make if ...........
the simple rule
north in the palm of your hand
signal in the direction of your finger
and it moves in the direction of your thumb
this should be true all over the diaphragm
sometimes we know very little, and sometimes we know too much
Old 21st September 2010, 09:07 AM   #52
Default HI BENTL
Tried your suggestion but gave up after a while, the magnets kept moving and touching each other. It would need the magnets being glued in position. And aluminium bars placed in between each row till the glue set. Then if there was no improvement in the sensitivity you would have a job removing magnets! I don't have the patience for this so will stick with my original design. If anybody out there feels up to the challenge ? I wish you good luck. You'll need it!
HENRY
Old 21st September 2010, 09:23 AM   #53
bentl is offline bentl  Norway
as long as one uses some distance pieces of plastic or wood its quite simple.
Picture shows first row in place. I put down the magnets with plastic pieces between them. Then I flip the panel upside down, and apply a drop of superglue through the perforation. The capillary effect sucks the superglue between the perforated plate and magnet and it sticks!
I discovered something strange when mounting the magnets - I used a little toy compass to determine the orientation. After a while the compass' magnetization was reversed and i started to mount the magnets wrong...
Now i have a "master magnet" where I have marked N and S and use it to determine orientation
the magnets are fittet with 25mm clearance to the frame, and 15mm distance between columns. 10 mm distance between magnets lengthwize.
Bent
Old 21st September 2010, 10:00 AM   #54
Default HI BENTL
Let me know how it sounds in comparison to the older design. Keep the pictures coming, well done. But shouldn't the magnets be around the other way? I would have placed the magnets 90 degrees differently I am confused by your layout! Must be getting old!!
HENRY
Old 21st September 2010, 10:13 AM   #55
JonasKarud's Avatar
Originally Posted by tinitus View Post
the simple rule
Left or right hand?
Reality is just a word....
Old 21st September 2010, 10:39 AM   #56
i don't think that the layout of the magnets matter very much.
If you arrange them in rows or columns you use about the same length of magnets and coil I guess (havent calculated on yet)
In my design I plan to run the alu conductor across the diaphragm without folding it - and connect the parallell conductors with a piece of wire with cable shoes.
As far as I know; Apogee used horisontal rows of magnets, while Magnepan uses columns. If you look at Båndsei's planars, he also uses columns of magnets and the design very diy-friendly in my eyes.
I will post some more pictures in a while but are trapped at work and the progress on the project is very low..
Old 21st September 2010, 11:54 AM   #57
Originally Posted by JonasKarud View Post
Left or right hand?
as you imply, it wont tell you the whether its actual north or south pole
it doesnt matter as long as you do it the same way all through
but its only useful at the theoretical design stage
as suggested by Bentl, during actual build its practical to have a small master magnet with poles properly marked
actual polarity on finished design is determined the usual and simple way, with small a battery
but be aware that non traditional magnet design could act very different from expected
its by far not simple
Old 23rd September 2010, 10:44 PM   #58
tmblack is offline tmblack  United Kingdom
What type of magnets are used ie N-S thru long side or NS on top/bottom face?
And how are the magnet poles arranged?
Old 24th September 2010, 08:17 AM   #59
Default hi tmblack
North and south on the large faces, I use 50 x 12.7 x 3 mm neo magnets. Magnets placed on the perforated steel sheet in alternate rows NSNSNS etc and the alu tape over the edges of the magnets ie between the NS interface. Hope this helps.
HENRY
Old 24th September 2010, 04:54 PM   #60
Yes a big help.
I found some that are 0.500" x 2.00" x 0.125".
What is a good place to buy them in North America, I found some for under $2 for very large number?
How many magnets did you use in a pair?
Does anyone know what size of magnet Magnepan and Apogee used?
The Magneplanar is much lighter than equivalent Apogee.
Full range planar speaker using neo magnets JAMESBOS Planars & Exotics 382 21st January 2017 03:53 PM
Anybody seen this type of planar speaker? WrineX Planars & Exotics 21 16th August 2015 09:28 AM
need help picking a planar speaker lochness Multi-Way 5 30th May 2007 08:42 AM
planar 25 vs planar 3 GAK Analogue Source 2 30th January 2004 03:38 PM
Copyright ©1999-2017 diyAudio
