Planar speaker - first try - Page 4 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 10th September 2010, 04:37 PM   #31
WrineX is offline WrineX  Netherlands
WrineX's Avatar
whooo thats sounds awesome james, i still have like 4 panels of magnepan smg a standing around with broken mylar or coils destroyed etc. im planning on recoiling it with the cpc security tape, wich is much lighter then the orignial coil, also foil can get rid of heat muich more easy then the wires so i might get away with less aluminium higher resistance lower weight but maybe can handle same power because of the better heat dispersion. only trouble might be the higher resonace frequency, so im planing on dampening with vilt and using 2 panels a side, and then use a electrostatic for the high freq 1K and up or even lower, depends on how low a verry small stat can go because i want dispersion to be good. i think we get best of both worlds with this design ,both are dipole speakers , magneplanar is better in low freq where stats own magneplanars in mid and highs. no expensive tranformers with huge stepups no saturation no mirror drive etc.
when i use all four pannels i could use them serie we might end up in 8 ohm range and spread the power. i would have a huge huge bass panel aroud the 2,2 meter high and a verry narrow tweeter/midrange of 3 cm width and 2 meter high (maybe less nobody is 2 meters long when sitting down )
wich such huge magneplanar i could lower the resonance freq of the bass without mylar hitting the magnets because they get half the power the would have normally
Old 11th September 2010, 04:57 PM   #32
Has anybody here tried
File:InfiniteHalbachArray.JPG - Wikipedia, the free encyclopedia
halbach arrays?
There is a new thread by Andrew Eckhardt ...
Kind Regards
Oliver, RFZ believer (?)
www.dipol-audio.de
Old 11th September 2010, 05:57 PM   #33
here is the article about Halbach arrays.I will try to make a femm sim.
Halbach array - Wikipedia, the free encyclopedia
Old 11th September 2010, 07:00 PM   #34
Here is my femm.simm.
[IMG]Click the image to open in full size.[/IMG]
Old 11th September 2010, 07:08 PM   #35
Hi bandsei,
In words ?
Usable or not suitable for isodynamic speakers,
when compared with your previous results ?
www.dipol-audio.de
Old 12th September 2010, 07:51 AM   #36
Baldin is offline Baldin  Denmark
Baldin's Avatar
Send a message via MSN to Baldin
Hi LineArray
I see a problem in that the HalbachArray will produce a "plate" of magnets with no airflow through .... you will always want the membrane to be as close to the magnets as possible, (trade off btw. field strength and Xmax) .... with the Hallbach you will at best get a high degree of compression ...
I haven't looked/simed at the field strength, but putting magnets close together with different polarisation I would think you loose a lot of strength ..... but thats only my guess .... so, no I do not think it is applicable for this kind of speakes ....
But thanks for taking it up
Visit www.sensibleaudio.dk or read latest news on Baldin's Blog
Old 12th September 2010, 08:53 AM   #37
Hi Baldin,
yes it was just a "quick shot",
i see the perforation problem ...
www.dipol-audio.de
Old 12th September 2010, 09:08 AM   #38
JonasKarud's Avatar
Henry, can we see some photos on your speaker?
Old 12th September 2010, 10:29 AM   #39
Here is a simm with the same magnets just 4 magnets can make a stronger field than 9 magnets in the Halbach array.
The curves B,t shows the strength tangential or as the wires in a planarspeaker "sees" it.
So Halbach won´t bee usefull for planar speaker´s
Old 12th September 2010, 06:32 PM   #40
Hello Bandsei,
thank you for your patience in analysing that !
Cheers
www.dipol-audio.de
Full range planar speaker using neo magnets JAMESBOS Planars & Exotics 382 21st January 2017 03:53 PM
Anybody seen this type of planar speaker? WrineX Planars & Exotics 21 16th August 2015 09:28 AM
need help picking a planar speaker lochness Multi-Way 5 30th May 2007 08:42 AM
planar 25 vs planar 3 GAK Analogue Source 2 30th January 2004 03:38 PM
Copyright ©1999-2017 diyAudio
