Planar speaker - first try - Page 13 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 11th March 2011, 11:28 PM   #121
Have finished my rebuild of a push pull double membrane with 555 neo magnets 50 x 12.7 x 3 mm. To a single membrane using only 185 magnets per speaker using 23 micron mylar A polyester as opposed to 100 micron polythene. It was a complete success and the sensitivity was a little more and a lot lighter as well. I am quite happy with this design and I won't be building any more double membrane designs.
HENRY
Old 11th March 2011, 11:59 PM   #122
Still can't send a picture, it says security token missing any idea how to get round this??
HENRY
Old 12th March 2011, 12:25 AM   #123
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
click on
go advanced
manage attachment
then you pick from your file
remember upload
if you have more than 3 pictures, just repeat the upload
some may need to be rezised
I rezise to 'large'
Old 12th March 2011, 12:20 PM   #124
Default latest rebuilds
These photos are my latest rebuilds
HENRY
Old 12th March 2011, 01:07 PM   #125
Default New New Rebuilds
This is a rebuild of the first FRP I built over 20 years ago using ferrites and angle iron, weighed a ton. NOW I have to rebuild the membrane using the Mylar A Polyester Film, keeps me out of mischief!! The smaller one on the left I use for a sub woofer.I will also rebuild this one using the thinner membrane. I also have another like this using push pull design.This is also a future rebuild with the thinner membrane I will also remove the push pull design.
HENRY
Old 16th March 2011, 01:36 AM   #126
Default New Amp 7.1
Will be using 5 pairs of FRP of my own design and build, 1 pair of which will be sub woofers, with my new 7.1 ONKYO Amp. I just have to rebuild one of my sub woofers using the 23 Micron Mylar A.I have already rebuilt one which was a push pull design, which wasn't an improvement on the original single membrane design hence the several rebuilds. I shall have to cut several of the tapes in half using scissors. I have quite a few yards of material for covering of the speakers. The hardest part is using my sewing machine!!??
HENRY
Old 16th March 2011, 01:42 AM   #127
Default Security Token
With the help of my son I have sorted out this problem and I am now able to send pictures as well!!
HENRY
Old 16th March 2011, 04:38 AM   #128
you could use this handy little device to test your field.
All you need is a signal generator which can be an amplifier and cd player playing a tone at very low level.
And a scope or digital voltmeter. jer
How to make a good transformer for ribbon tweeter?
p.s. I love the you tube video and I can definitely tell they have great sound even with the cheapy microphone. great job! jer
Old 16th April 2011, 05:08 PM   #129
R. Jamm is offline R. Jamm  United States
Henry,
Have you tried ribbon tweeters with your planar speakers?
Old 17th April 2011, 01:33 AM   #130
No need already full range, have enough work with the rebuilds., using the 23 um mylar A. Improving the design would need a total rethink. Which at this moment in time is beyond me.
HENRY
Full range planar speaker using neo magnets JAMESBOS Planars & Exotics 382 21st January 2017 04:53 PM
Anybody seen this type of planar speaker? WrineX Planars & Exotics 21 16th August 2015 10:28 AM
need help picking a planar speaker lochness Multi-Way 5 30th May 2007 09:42 AM
planar 25 vs planar 3 GAK Analogue Source 2 30th January 2004 04:38 PM
Copyright 1999-2017 diyAudio
