| Planars & Exotics ESL's, planars, and alternative technologies |
#11 |
Our living room is part of the apartment in a block, any problem with that?
So, you can`t hear a difference between sine waves of 22 and 25 Hz reproduced through speakers? A great expert indeed. Good luck with finding great sound in your religious books and may God bless you for getting outta here.
Loudspeakers From Abyss |
#12 |
I do agree with your speaker placement as a starting point for a dipole. we have done so for decades now using the last 1/3 of the room for the seated position. Still yet mucho treatment is still necessary to get the best and with your set up we have found diffusing to be better than absorption, which works better if you are setting the speakers up in the first 1/3 ... regards, |
#13 |
Thank you a.wayne for your kind response, I will respond tomorrow as I am leaving for a rock concert now!
All the best, miro
#14 | |
The cross over is set at a rather high 150 Hz which really takes the bass out fo the CLSs and puts it down in the SUB. This pushes the sub up about has far as it can go frequency wise, and takes enough bass out of the CLSs so that the pannels (and transformers) are not trying "so hard". Mitch |
#15 |
I have recently heard Ivan's setup. Truly impressive. Doesn't cost you a penny, why don't you give yourself a treat and give it a try?
#16 |
Thanks Miro for sharing. I am only 1 year late to the party but I think what you shared is worth trying.
It amazes me how many people kill their dipoles by racking them up against a wall. Pull those puppies out !!! A friend of mine had a 10 x 20 foot room to work with. He did the typical mistake of placing his Acoustats about 4 feet away from the wall. When the audio store owner came over to help him he said car stereos sound better. After a couple of hours of speaker setup they ended up around 11 feet off the wall and very close to the side walls. Then the owner said this is one of the best audio systems I have ever heard. It was shockingly good. I spent many hours listening there. While the sound stage could have been wider the depth, focus, and 3D world was stunning. This was back in the early 80s. I have found from experimentation that 6 feet is better than 4 off the wall, 8 feet still better, 10 gets real good, and 12 is utopia. Rocket_out of the box_Ronny
-Mac Powerbook into McAllister PP-150 driving GR Research OB-5 speakers. |
#17 |
It's perhaps even better without a wall at all.
![]() Wachara C. |
| FR Bipole; room placement? | Jeb-D. | Full Range | 3 | 28th July 2006 07:27 PM |
| DC coupling capacitor placement | Nordic | Chip Amps | 1 | 11th October 2005 07:25 PM |
| placement, setup, and room issues | xstephanx | Multi-Way | 10 | 19th May 2005 01:56 AM |
| Sunfire True Subwoofer room placement | The Paulinator | Subwoofers | 3 | 15th December 2004 06:52 AM |
| Loud Speaker Crossovers and power amp placement | JRKO | Multi-Way | 20 | 1st August 2004 11:07 AM |
