| Planars & Exotics ESL's, planars, and alternative technologies |
I was playing around in Google sketch-up trying to come up with a lower profile version of a traditional H-Frame or even open baffle woofer. This sketch is a top view for a woofer designed to roll-off between 200-300Hz and augment a full range driver.
The woofer would be wired with reverse polarity in relation to a full range driver. The front of the driver fires into a chamber which exits at the rear of the design to help isolate the rear wave. The design may also benefit from a slight horn-loaded shape facing front. Note that the top of the chamber would be solid to minimize wave interaction. Im interested in your initial thoughts with regard to possible advantages/disadvantages over a standard open baffle design. Also, any guesses as to how SPL would be affected in comparison to an open baffle, H-frame, etc. Thanks as always! |
#2 |
To me it looks like a cross between Z Frame and a Ripol.
The narrow path facing the cone will introduce some mass reactance, since it sems less than the cone's area in cross section ? I do not state this being good or bad, but the free air resonance of the driver will lower somewhat and the Q will rise. This may be desirable for many drivers. The dipole path length seems a bit short, making it longer would decrease the displaced volume needed for a certain SPL goal. Horn like shape is very much less important than dipole path length. A flared "port" may reduce noise, but there will be no serious effect in SPL i feel. I guess you have consulted Linkwitz' spreadsheet to estimate max SPL due to dipole path length and displacement volume for your driver ? Kind Regards Oliver |
#3 | |
Hi Oliver, good to hear from you again.
With regard to measuring the dipole path at the front of the enclosure (rear of the driver), this is a bit challanging due to the irregular relation of the driver to the side walls. I suppose I could go for an average measurement, an imaginary line drawn from the center of the magnet out until it's parallel to the end of each wall? It might be easier for me to build the "carrier" this weekend, and play with the length of the side walls, and depth of the chamber, and measure the result. Ed |
#4 |
Your dipole might have a strong resonance around 200 - 300 Hz.
Bruno |
| Good woofer 2-way dipole | FORNO | Multi-Way | 16 | 22nd August 2010 08:14 AM |
| Dipole Ribbon tweeter isolation from dipole mid-woofer array | Bent | Planars & Exotics | 5 | 21st May 2009 12:10 PM |
| Dipole woofer how high | johnb | Subwoofers | 3 | 5th November 2005 10:11 AM |
| Newbie Dipole woofer help please... | santiu | Subwoofers | 5 | 30th October 2005 07:20 PM |
| Dipole Woofer Page | BAM | Multi-Way | 8 | 8th December 2003 10:49 AM |
| Page generated in 0.10047 seconds (78.59% PHP - 21.41% MySQL) with 11 queries |
