| Planars & Exotics ESL's, planars, and alternative technologies |
BTW, I did read up on how to repair the MMG's through some of the threads here. But I was wondering, if the wires are held in place from residual stickiness (I cleaned the area with acetone) just enough to secure with scotch tape, why would this not be a permanent fix?
Originally, while attempting to fix (or further ruin) my Gamut amp...something went haywire, and I started smelling something burning. By the time I realized that the smell was emanating from the speaker...the wires (from the heat) unglued themselves from the mylar diaphragm, but only from the middle part of the panel. Seems to be working fine. No vibrations at all. I don't think that there would be a weight issue with that little amount of tape eh? Thanks Spiro |
#3 |
can you kindly post a pic of the repair you made without the tape?
The only true wisdom is in knowing you know nothing. A wise man does not need advice and a fool won't take it. |
#4 |
Mavric...thanks for the interest.
Well, I didn't take any pics before repair...I'm trying to get into the habit. But basically the wires got VERY hot and unglued themselves from the diaphragm in the middle part of the speaker. I was deciding at that point whether I was going to try to repair OR use the speaker as an upright bass! HAR HAR! After cleaning the area with acetone, there was still a residual stickyness...so I realigned the wires...and used the scotch tape for temp solution. The damn thing works like normal. I'm just wondering if there are certain principles effecting sound that this is contributing that I am not aware of. Any ideas? thank you Spiro |
#5 |
I think like your first experienced, HEAT is a design and material consideration.
I think there is a special glue for this which you should be using, but it needs to cure/dry before using or a fire will result. I think you should contact Magnepan about the situation and see what they say.
Tubes and Martin Logan's Last edited by kach22i; 14th June 2010 at 08:20 PM. |
#6 | |
Cheers |
#7 |
Well, by using tape you are incresing the mass of the membrane, which will affect both sond and will be meassurable.
The tape will also have a dampening effect. You will probably have a little less output at hig-mid feq. The tape will almost for sure not last, and you might start to get a mecanical sound from the wire moving but not entirely together with the membrane ... especially with hugher volume.... I would go for gluing them as proposed by kach22i Beat regards Baldin |
#8 | |
![]() Cheers |
#9 | |
The Planar Speaker Asylum Regards, Andy |
| Hi Pals & Gals | messenger | Introductions | 2 | 8th June 2010 01:18 AM |
| All you horn guys and gals | Variac | Multi-Way | 6 | 17th June 2003 08:27 PM |
| Hi Guys! I'm one of the Portuguese Guys who love diy | sapito | Introductions | 3 | 2nd September 2002 02:19 PM |
| Page generated in 0.12143 seconds (80.44% PHP - 19.56% MySQL) with 11 queries |
