| Planars & Exotics ESL's, planars, and alternative technologies |
Hello,
I have been reconstructing the ESL 63 for some time now but I'm in a dead end. I could get one speaker to work properly (victory!) but not the other one (misery!). I have already tried a few things but with no result. Let me try to describe the situation, to see if you can suggest any good idea: - The speaker plays music but with lower level when compared with the other one - the charge indicator looks good, with a blink every 2 seconds or so - I cannot detect any distortion, or clicks and pops, the treble seems a bit recessed though - I tested all 4 panels and they are all working - I tried disconnecting each one individually, but with no result - The electronics was working ok before, and I have changed panels from one speaker to the other with no obvious indication that one was faulting - My last attempt was using tape around the sides of the panels to avoid leaks, this seems to have improved the situation, but not solving it Any thing that I may be missing? Many thanks for your help. |
#2 |
#3 |
All the panels and the electronics work OK, but the sound coming from one speaker is too low.
#4 |
#5 | |
It's a fairly common fault that one of the capacitors on the HV bias board is "open". I always change all the caps and rectifiers on these boards when I refurbish Esl 63 speakers. |
#6 |
Did you change the diaphragm? If yes, your coating on the diaphragm might not be good enough (too thin, resulting in too low conductivity). This would result in low sound level.
Wachara C. |
#7 |
#8 | |
You may have a good point though. The instructions on how to spread the coating are quite straightforward, but the results seem a bit too thin when compared with a panel redone by One Thing Audio that I have for benchmarking. Can I spread the coating again, after cleaning with alcohol, or am I condemned to change the diaphragms? (the worst part is cleaning the glue, to say the truth). I would have to do it on the 4 panel. |
#9 | |
I confess that I'm on the verge to simply give up. I had to go back to my previous speakers and they sometimes seem an upgrade compared with the 63. I know it sounds apocrypha, but I'm enjoying again high treble and some sound pressure... |
#10 |
It would be a "High Voltage Test Probe" connected to your meter. See below:
LUTRON HV-40: VARIOUS: Test, Tools & Supplies
Kevin |
| Gradient Sw-63, Quad-63 Esl | Williams Audio | Swap Meet | 5 | 29th March 2009 03:16 PM |
| Quad ESL 63 problem. Please help | DirkD | Planars & Exotics | 9 | 4th October 2005 02:03 PM |
| Quad ESL-63 rebuild | I_Forgot | Planars & Exotics | 9 | 7th March 2005 06:36 PM |
| QUAD ESL 63 noises | tabaregg | Planars & Exotics | 2 | 15th December 2004 10:28 PM |
| Parts for the Quad ESL 63 | Buhl | Planars & Exotics | 23 | 4th December 2004 07:32 AM |
